It is currently Sat Aug 02, 2025 5:11 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 08, 2005 8:02 am
sweet 8) that's how I did it at 1am this morning. THAT'S the latedt I have worked in JAM before....you can tell I am close!!
I'd appreciate the 'Dr Mini Special Tuning' when I am ready to fire it up :wink:
PostPosted: Fri Jul 08, 2005 9:09 am
High heel ninja
Anton, you can bleed the clutch on your own, put a peice of hose on to the bleed nipple and put the other end into the clutch master cylinder, crack the niple & pump, it just goes around in a circle, put it till you get pressure lock the bleeder, then grab the hose with a pair of pointy nose pliers & pull it off, lave the other end in the cylinder & drian the fluid out of the hose back into the master cylinder, clean & easy way of doing it.
Doogie
PS are you going to get JAM *** number plates for it?
PostPosted: Fri Jul 08, 2005 10:15 am
Hey Anton, will there be an unveiling of JAM??
Jet Red Mini K
PostPosted: Fri Jul 08, 2005 10:22 am
i would drive from here to see this unveiling.
:( not im my mini though
I have a problem.. apparently
PostPosted: Fri Jul 08, 2005 10:27 am
Very Exciting!!! :D
Lillee - 1969 Morris Mini K
PostPosted: Fri Jul 08, 2005 4:13 pm
NAV-MAN
Got the indicators working yet JAM???
PostPosted: Fri Jul 08, 2005 9:01 pm
been in Newcastle all day....haven't touched JAM today :(
I think the indicator flasher unit is cactus...I reacall JAM being the same prior to resto.
PostPosted: Fri Jul 08, 2005 10:35 pm
you can get new flasher cans that are solid state, if its hidden away no judge will ever notice and they give consistent flashes all the time.
