It is currently Tue Jul 29, 2025 4:04 pm
PostPosted: Fri Jul 08, 2005 5:55 pm
My tire's are indeed close to needing replacement, but i had it up on a hoist this afternoon getting some exhaust work done, and the front LH tire is bald on the inside, none of the other's are..all of them have more wear on the outside from cornering i guess, but it's only the inside of the front LH tire that seems odd..
any ideas?
PostPosted: Fri Jul 08, 2005 5:58 pm
Get a wheel alignment.
The left wheel is the one that spins, keeping that in mind.
ALso, mine wears on the OUTSIDE first, indicating some positive camber... yeah me needs a wheel alignment too. 8)
PostPosted: Fri Jul 08, 2005 6:04 pm
I forgot to mention i just had an alignment..
Is it alway's the left wheen that spins? cause that could be it :lol:...there's lots of spinning going on :mrgreen: I think both of them spin though...
PostPosted: Fri Jul 08, 2005 6:08 pm
Nar most chances its just the left that spins.
Check the marks in the driveway for evidence :wink:
Yeah wheelspin is good stuff... cept when it comes to new tyre time :lol:
PostPosted: Fri Jul 08, 2005 6:35 pm
oh so you guys have only 1 wheel spinning as well then? i though i had an error. not that i do it much anyway. only on grass and gravel :D good boy
78 Leyland Mini - Prince
PostPosted: Fri Jul 08, 2005 6:37 pm
It hits two wheels if you turn the wheels... but don't do it or you can say bye bye to your diff :cry:
PostPosted: Fri Jul 08, 2005 6:39 pm
speaking from experience are we will?????? :lol:
PostPosted: Fri Jul 08, 2005 6:40 pm
Not direct experience...
mate has had it happen before tho :lol:
Shears teeth off the pinion and a lot of other nasty stuff :shock:
PostPosted: Fri Jul 08, 2005 7:12 pm
I know someone that had the CV joint come out when they were doing reverse donuts
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Fri Jul 08, 2005 7:20 pm
Still seems odd...go around a round-a-bout...hook it left, then right..spin the inside RH wheel around from weight transfer and direction of the wheels, then left to exit...spin the LH front...
It depends which way the wheels are facing, as to which wheel will spin..maybe if wheels are dead centre, it prefer's the LH wheel? but if you turn it right it will spin the RH and turn left it will spin LH...
PostPosted: Fri Jul 08, 2005 7:23 pm
When they did the alignment, was it only the toe out they checked? Did they check castor and camber.. maybe something is bent or worn... :?
PostPosted: Fri Jul 08, 2005 8:20 pm
It's cause it's a clubby that's why :lol: Sorry couldn't resist
I was just about to say that, "Wheel alignment" is a badly used generalised term :shock:
PostPosted: Fri Jul 08, 2005 8:26 pm
Your on a roll tonight aren't you chongly :lol:..let's get a hack saw to lilly and put a clubby front on her :P
Hmm...I got it aligned at Mr. Bob Janes..not sure what they did..
I know my diver's side tie rod has a little bit of a bend in it..passenger's side is straight...
There is a knock also coming from this side when I take off...it's not engine related, definately suspension ball joint, bearing play maybe?
Bearings got replaced a little over 6months ago though...timkens too..if i hold the wheel at 12 and 6 and try to rock it, there is about 1mm play total..drivers side has none..zip..squat..
It was up on a hoist today getting the exhaust done and I had a closer look, couldn't really find anything obvious... but i didn't get a great look..
PostPosted: Fri Jul 08, 2005 8:31 pm
Assumption- by `tie rod' you do mean the tie bar that runs forward to subframe..
If a tie bar is bent, that will increase castor, and as the bottom arm is mounted at an angle, alter the camber a little bit too. :roll:
Go buy some nice HD adjustable tie bars (& new rubbers) from Karcraft or somewhere.. :wink:
Or, at least remove and straighten that bent one.
PostPosted: Fri Jul 08, 2005 8:32 pm
A knock when you take off: CV? Pot joint? are the rubbers all ok?
Actually I might have to do this one day as there is rust up the front there :lol:
Users browsing this forum: No registered users and 64 guests
