crazy_bunny wrote:
just pulled the top of the bowl and im not getting any fuel from it.. ie the pipe is connected ont he outside.. but doesnt come thru near that float thingy..
Anyideas as to why it mite be blocked/how to unblock it?
how old is the rubber tubing going to the float bowl? Carefuly, very carefully (petrol sometimes = fire) remove the tube at the float bowl and poke into a suitable small container....turn the engine over....does fuel come out the pipe??? Yes?? Its the carbie like Morris1100 said...strip and clean.
No fuel? do you have a mechanical or electric pump?
Mechanical....lift the top off it...dry? could be the pump or hey the problem may be further back...new lines...so could be a tank blockage causing a problem??
Electrical...power getting to it OK?? Yes??...pull it out of the line and see if it looks gunked up....if it is an SU it may need the points cleaned....etc etc
keep looking...process of elimination
