It is currently Sun Aug 03, 2025 12:31 am
 Post subject: buffing stuff
PostPosted: Tue Jul 12, 2005 11:38 am
So where do people in Sydney get there buffing pads from?
I have been advised that wool is the best. I have also been advised that
foam is better....??? I am prob going to go wool. Foam just doesnt seem right
to me :?
Also was advised the best rubbing compund for the first buff is stuff called
**** in a little tubefrom repco.
But my main qstn is about the buffing pads. where from. does quality vary
or is a buffing pad a buffing pad
PostPosted: Tue Jul 12, 2005 11:47 am
Dude, buy $2 maguirs foam pads from supercheap. When they get crappy throw them out. You don't want to reuse an worn pad...
Just buff it out using your mum's best winter pajamas :wink:
Works for me, then again I have ultra hard 2 Pack...
PostPosted: Tue Jul 12, 2005 11:51 am
yeah when buffing a normaal car i use microfibre cloths and sh!t
but cos the car needs its first buff it needs to be buffed by machine
to heat the paint uup to get it shiny. so this time round mums pjays just
wont cut it :lol: :lol: :lol:
Ill go try holden paint supplies or maybe repco
PostPosted: Tue Jul 12, 2005 11:52 am
does quality vary
YES!!
I bought a wool pad from my usual paint/panel supplier and it was good. I then dug out an old one from the same supplier (about 10 years old, but harldy used) and it was AMAZING!
Thick wool pads are what you want....none of this thin and whispy stuff...
A mate of mine is a panel beater and he only uses foam pads.....
At the end of the day it's what works best for you.
My local repco have foam pads, and the attachments for your buffer....but thay aint cheap. The foam was $45 alone!!! :shock:
I use 'buffing compound' in a tin. It's water based and green in colour. You water it down and apply by hand (with a Meguaries foam hand applicator) and machine buff off :wink:
I will redo mine in a week or so. 8)
PostPosted: Tue Jul 12, 2005 11:55 am
ok so where do i get these thick ones from? I have a thing about using
foam. it just doesnt seem right....
Anton try this **** stuff for the buff if you do it again. My panel beating mate
used to be one of the best, (amazing quality work) and he uses this
stuff all the time and wont use anything else. he reckons its the best.
PostPosted: Tue Jul 12, 2005 12:00 pm
czerial wrote:
Anton try this **** stuff .
more info?
Get your buff pad from a panel beater supplier...not repco or Kfart... :?
PostPosted: Tue Jul 12, 2005 12:01 pm
you just get it from an auto supplier in a little tube. a little goes a long way.
relatively cheap too. but the BEST. i am going to go buy some today,
Where are panel beater suppliers?
PostPosted: Tue Jul 12, 2005 12:10 pm
http://www.yellowpages.com.au/siteEntry.do
PostPosted: Tue Jul 12, 2005 1:26 pm
just got everything. GREAT place on queens rd fivedock peps. they have
EVERYTHING and full of advice,
They steered me away from freckler as it is more of a compound for tpac (my
friend must have assumed thats what i was using) and am using some green stuff
so prob the same as you anton. plus the good wool buffer and 1500. yay
cut back time
have a nice day
PostPosted: Tue Jul 12, 2005 1:32 pm
use 2000 grade paper after your 1500
PostPosted: Tue Jul 12, 2005 1:33 pm
i have been using foam pads now everyday for 5 years and they are great. I used the wool pads at the start but was leaving swirl marks no matter what compound was used...
If your doing your van id say get some meguairs level 4 (medium-hard) cutting compound in it. With a very soft (black waffle pad) on a pretty high speed buffer.
Then wash it and go over with a nice hand polish (mothers is fine) then finish with a llight coat of wax.
Should of gave me a call, all the bits and pieces you need will cost a bit, i do mini exteriors for $50 (ausmini members only) :D
1974 Moke - 998cc
PostPosted: Tue Jul 12, 2005 1:39 pm
i might give you a call for the Van brad. that is in need of some TLC!!
This buffing stuff is for Elmo.. So you reckon go 2000 after the 1500, why is that
Anton? wont the buffing get everything out? or is 1500 too coarse? Most pep have
been telling me 1500 then buff/??
PostPosted: Tue Jul 12, 2005 1:40 pm
yea Brad I reckon you can do JAM in a week or 2 for that price :wink:
Will supply beer for nix :wink:
PostPosted: Tue Jul 12, 2005 1:49 pm
hey anton tell me bout why the 2000??
PostPosted: Tue Jul 12, 2005 3:05 pm
Hey brad i will get you over to do the van and the pt once i finish the van and it stops raining. Probably in 2-3 weeks. Do two cars at once and saves you the hassle of going from one to the next. :D
Aaron
