It is currently Thu Jul 31, 2025 3:50 pm
PostPosted: Tue Jul 12, 2005 4:57 am
And i quote:
To make it easier to work on major restoration work, here is a few pictures and measurements for putting together a rotissaire on which you can mount your Mini. As the cars usually rust from the bottom up, life is a lot simpler when you can spin the car around to work on the bottom. This make welding, painting and mounting all the fuel and brake lines a standup propostion, instead of lying on your back.
Full details (6 pages) here ---> http://minimikebc.tripod.com/rotiss.html
PostPosted: Tue Jul 12, 2005 9:13 am
yea that has been online for a while now.....the whole site is good reading.
PostPosted: Tue Jul 12, 2005 10:06 pm
Looks much like the one I borrowed... 8)
If you build one make sure to put some castors on it.. verrry handy. :wink:
PostPosted: Tue Jul 12, 2005 10:15 pm
They're very good....well worth the effort of making one altho i didnt make mine!
[Maverick] 1971 Mini K
PostPosted: Tue Jul 12, 2005 10:21 pm
I'd say you would wont brakes or stoppers on it..you dont wont it running out the drive way :shock: :lol:
PostPosted: Tue Jul 12, 2005 10:38 pm
I had no problem- it can't run away uphill!
 Post subject: cross bracing
PostPosted: Wed Jul 13, 2005 6:24 am
I didnt fit any of the cross bracing inside my clubman while on the spit, do you think that makes much differance?
PostPosted: Wed Jul 13, 2005 6:52 am
You only need to crossbrace it if doing major panel replacement like a whole floor, IMO.
I put 2 front floor pans in the 850 (1 at a time), measured door openings & squareness before and after, was no difference. :wink:
PostPosted: Wed Jul 13, 2005 9:31 pm
Any ideas on features that a rotissary should have?
Casters, rotation clamps, height adjustment?
PostPosted: Wed Jul 13, 2005 10:47 pm
The one I borrowed came apart in bolted sections for easy storage & transport. It had the pole supported in a 1/2 pipe welded on each end frame. To fix rotation, the pole had a plate with 8 holes in to that lined up with one in the front frame, and a 1/2" bolt. So it could be fixed at 45*, 90*, 135*, 180* etc. And it was failsafe- couldn't slip out of position. :wink:
I'll bung some pics up tomorrow nite.
