It is currently Sun Jul 13, 2025 7:14 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Wed Jul 13, 2005 9:45 pm
Hi guy's, ever since I bought snoball I keep looking at the RX7 and wondering if the all-mighty Rotary can breath life into my morrie, and would wish it so.
I am putting out a request for help on finding information that can help me on achieving my mission of Rotorizing a mini. Anything would be greatly appreciated; all information will be looked into.
Wish me luck!!!!!! :wink:
68' Morris, 1100,
Willson Automotive
Tasmania's ONLY mini Specialists
(03) 62725056
http://photobucket.com/albums/a323/the_white_one/
PostPosted: Wed Jul 13, 2005 10:03 pm
mate i wish you luck as i can say it will not be easy
i have seen one or two attempts and they needed a large tunnell through the car its the torque you cant use a mini box
no way rx7 engine need a small one
PostPosted: Wed Jul 13, 2005 10:05 pm
its been done here on the sunshine coast, QLD. company called 'rotormax' has done this conversion several times.
they use a mitsubishi cordia gearbox. I dont have much more info then that. im sure you could find rotormax in the white pages though.
Last time I talked to Doug at rotormax the conversion cost about 7 grand drive in drive out. that may have been with a supercharger as well though, can't remember, it was a couple of years ago.
'68 Morris Mini Matic (GF's)- complete!
'68 Morris Mini Deluxe - deciding on specs..
'63 Morris 850 - On the Shelf
Other various mini parts cars :)
PostPosted: Wed Jul 13, 2005 10:15 pm
the same engine thats in an rx7 or a smaller one???
PostPosted: Wed Jul 13, 2005 10:33 pm
probally a 12a for front wheel drive use
PostPosted: Wed Jul 13, 2005 10:57 pm
I've heard they just used a single rotor. Probably 13B.
PostPosted: Wed Jul 13, 2005 11:20 pm
Sorry man, but mazda only ever made single rotarys in concept form.
10A,12A,13B are all twin rotors! 8)
Yea, i recon i'll drop a stock 12A 4/6 port with EFi, *MAYBE* an Extend port, anymore would be stupid!!!
Fwd is th go, Rwd would be waaaaaay too expensive!! :wink:
68' Morris, 1100,
Willson Automotive
(03) 62725056
I spoke to Rotormax a while ago, the fella's name is Doug. nice guy...
As has been mentioned in other forums, he used a nice new 13b, minus one rotor, which i think makes it some kind of 10a *shrugs*.. He used some VW adaptor plate to mate the motor to a cordia box, although i have no idea what kind of VW, im fairly sure its not a stock car, there special plates for some competition engine swap application i think.... And i think the carb (downdraught webber) fouls the bonnet in the conversion, making a scoop neccecary, like the one on my ugly machine heh... He said the exhaust was just a single pipe!... he also said they are quick, with 14,000 rpm on the cars, although i dont know how reliably, how long... but they are running in a mild state of tune... Torque is also a concern... my 1330 pull hard from down low... i dont want to lost that, and im not game to fork 8k to find out i have!
G
--Insert legal disclaimer here--
PostPosted: Thu Jul 14, 2005 7:10 pm
damn that would be sick i'd need delaxatives so i would stop myself shittin myself
the only bad thing is u could only drive it on the dragway as you wouldn't be able to engineer it
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Thu Jul 14, 2005 7:52 pm
i guess doug would be setting the motor up North/South if he was using a VW box/transaxle, hence the loss of one rotor. But id be doing it East/West. And as for engineering it, i think it could be done. The only issue is what gearbox, and what subframe work would be carried out.
68' Morris, 1100,
Willson Automotive
(03) 62725056
PostPosted: Thu Jul 14, 2005 11:04 pm
you would be best of modifying a standard subframe, as for what gearbox look for a relivly short fwd gearbox and get a custom plate made up to match it to the rotary
PostPosted: Fri Jul 15, 2005 7:42 am
If he used a Cordia box it's mounted east/west. As for the `VW adaptor plate' it's probably the one that's used to adapt other motors onto VW boxes- as is/was common in open wheeler race cars & hillclimb specials. :wink:
Why only use 1/2 a 13B? Maybe it's to get under the cc limit for a road Mini...???
PostPosted: Fri Jul 15, 2005 10:52 am
does anyone know what the cc limit for a road going mini is?
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Fri Jul 15, 2005 4:16 pm
in NSW it is 3x the body weight NA,,,,, 2.5x the body weight turbo
So to put a 12a in a mini it must weight in at 800kg as i think they class a 12a at 2400cc
1974 Moke - 998cc
PostPosted: Fri Jul 15, 2005 10:47 pm
Is it really worth the effort?
6 port 12a around 80kw and lacks tourque, drinks fuel like a family six cylinder and unreliable
You can get a better result and save money sticking with the A-series,G13b, Starlet turbo etc.
Believe me Ive owned a couple of rotaries before turbo and bridge-ported they are a headache and technology with conventional engines has caught up and surpassed the efficiency of a street rotary.
