It is currently Sun Aug 03, 2025 2:49 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: wheels
PostPosted: Fri Jul 15, 2005 6:47 pm
im building a mini. for the wheel size if i get a 13x7, does it handle better or worse than a 10x5
PostPosted: Fri Jul 15, 2005 7:15 pm
worse.
I went from 10x5 with crappy tyres to 13x6 and it handles about the same,, 10x5 with good tyres will be better for comfort and handling.
1974 Moke - 998cc
PostPosted: Fri Jul 15, 2005 8:21 pm
....and look the part 8)
PostPosted: Fri Jul 15, 2005 8:27 pm
There is a happy m,edium. 12" wheels with 165/60/12 tyres
PostPosted: Fri Jul 15, 2005 8:59 pm
Just in case you are wondering, mini_man01, it's the fact that they are 7" wide that will make them handle worse, not because they are 13" in diameter. Also, with 13" wheels, you'll have to cut away at the arches.
I agree with ozmotorsport. Grab some 12"x5" rims with 165/60/12 tyres. I went the 12" because (depending on the style of the rim), the 13" can look too big on a Mini - my personal opinion, don't have a sad. :wink: 12" fill up the space a little more if that's what you're after.
Jonathan
PostPosted: Fri Jul 15, 2005 9:04 pm
Also if you go with 12" wheels you have a bigger choice of brakes.. disc brake options are pretty limited with 10" wheels.... as I know (got 3 sets).
I also reckon 13s are too big for handling- 12x5 are a good choice. 12x6 would be even better but I haven't seen them in Oz yet.
PostPosted: Fri Jul 15, 2005 9:07 pm
10s are the ULTIMATE wheel.
Racers use them. :wink:
Best all-rounder.
Piss these bloody 12" and 13" rubbish things off :)
Big willy
Advocate for 10" wheels. :D
PostPosted: Fri Jul 15, 2005 10:10 pm
yeah, 10" wheels are great.
if you want your mini to look like a fork lift
PostPosted: Fri Jul 15, 2005 10:25 pm
They DO look proper on a roundnose though, as Mr Issigonis intended. :wink:
PostPosted: Fri Jul 15, 2005 10:49 pm
big willy wrote:
Big willy
They must be good then :roll:
PostPosted: Sat Jul 16, 2005 12:24 am
Best all-rounder.
Big willy
I like 'em all..depends what your after..
With 'S' Brakes..10's on a roundnose..
On any clubby...12's for looks and braking and handling compromise..
13's for looks if that's your thing on all of them..
Racer's also use 12 and 13's if i'm not mistaken for the front so they can fit better brakes ;)
PostPosted: Sat Jul 16, 2005 12:30 am
Forklift?
Mini?
Where are the forks when you put the 10" wheels on?
Ultra confused at that lame comment :?
Also... try find me a picture of a proper racing mini with 13s.
Good luck 8)
PostPosted: Sat Jul 16, 2005 12:42 am
These count?
PostPosted: Sat Jul 16, 2005 12:47 am
So these wheels would be ok (ride/handling-wise) on the mini? (they're 12x5, polished diamond cut)
http://www.minisport.com/classic-mini-shop/products/exterior-styling/alloy-wheels/superlite/superlite-wheels/superlite-5-x-12-silver-polished-product.html
...Or these (12x6)
They're from...http://www.minispares-online.co.uk/
PostPosted: Sat Jul 16, 2005 1:00 am
That first Superlite is a 13 x 7...
