It is currently Fri Jul 04, 2025 1:18 pm
Post new topic Reply to topic  [ 68 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Sat Jul 16, 2005 7:40 pm
Is there anyone out there who has fitted NEW plastic brake and clutch master cylinders? The ones you get from Karcraft or the like.
I bought new ones and I am pretty sure I fitted then correctly. I took them from the box and matched the part number on the box to it's application.
Th eonly visible difference is the base of the cylinders. One is a slightly different shape to the other.
If anyone else has the same master cylinders fitted to their Mini, can you please confirm that yours are the same as mine pictured. Brake shown on the left, clutch on the right. The base of one is smaller than the other. I have this one on the clutch side.
Ta.
PostPosted: Sat Jul 16, 2005 7:49 pm
i don't have those types, but i have the new tin types. They look the same Base wise to me. So the way you have them on there is correct. The brake Base is slightly thicker than the clutch one. It should be right.
All i can sugggest is keep bleeding them. Those rear lines take forever to get air bubbles out of. Make sure your rear drums are all adjusted up.
Aaron
PostPosted: Sat Jul 16, 2005 7:57 pm
thanx mate. Maybe I am wrong in expecting to have both the clutch and brakes right after bleeding them 5 times each.
You are right...the rears took FOREVER to get right....and yea, they probably still aren't right. At least I have a way of bleeding them without having to ask the wife for help.... :lol:
What about brake fluid? The guy at the spare parts place said I can mix DOT 3 and DOT 4 type fluid. I have done that, but the DOT 3 was blue colour and the DOT 4 was yellow/clear colour. Is that cool to mix them?
(that brake line looks bad in that pic.....It's not so bad in real life....but I might replace them anyway :P can't have old parts in JAM :lol:
PostPosted: Sat Jul 16, 2005 8:11 pm
Well i am dodgy and mix the brake fluids up all the time, but they always work. When i bled my brakes the other day i adjusted first and then using the long return house sat there pumping the brake pedal for 5-10 mins each wheel while i read a book. TIP, swap feet on each wheel change. I will also do mine again once the motor is in too. It can take forever, but as someone will telll you if he gets online and sees this. Get them so they work and then take it to a garage and get them to do it. :roll: I think i should have mine right enough though.
Aaron
PostPosted: Sat Jul 16, 2005 8:20 pm
I bled front passenger, then front driver, then rear passenger, then rear driver sides.....
is that right?
PostPosted: Sat Jul 16, 2005 8:24 pm
Do them in order of distance. rear passanger, then rear driver, then front passanger and then front driver. This may not be right, but it seems to work for me. :shock:
Aaron
 Post subject: brake bleeding
PostPosted: Sat Jul 16, 2005 8:30 pm
you always start with the longest line from the master cylinder, passenger side rear then drivers side rear, nest passenger side front and last drivers side front, exactlt the opposite of what you have done, sorry
Jon
PostPosted: Sat Jul 16, 2005 8:33 pm
:lol: typical....
cheers for that....will rectify tomorrow :wink:
PostPosted: Sat Jul 16, 2005 11:09 pm
And, don't pump them- it will just aerate the fluid. Even worse, never tip the drained fluid back in. It takes ~24hrs for any air in it to separate out.
I PM'd you re the bleeding, etc.. :wink:
PostPosted: Sun Jul 17, 2005 7:59 am
i hope that is the clutch issue.... :?
PostPosted: Sun Jul 17, 2005 7:08 pm
J_A_M wrote:
:lol: typical....
I have a power bleeder - runs off your compressor and sucks fluid into a plastic reservoir on the unit (looks a bit like a spray gun but sucks instead of blow). Means you still have to stop and refill the reservoir, but you don't have to pump. Welcome to borrow it if it's any use to you Anton.
KB
PostPosted: Sun Jul 17, 2005 7:23 pm
Well I had a looksee today, no air in clutch, the clutch issue seems to be the pedal height is low to start off with. Reduces the pedal stroke and clutch throwout. Clutch clevis pin in pedal is a couple of mm higher than the brake one..
Cause will be apparent when he pulls it back out I guess.... :wink:
PostPosted: Sun Jul 17, 2005 7:37 pm
1310/71 wrote:
I have a power bleeder....Welcome to borrow it if it's any use to you Anton.
KB
KB, I might take you up on that next weekend :wink: Cheers mate.
Well I had a looksee today....Clutch clevis pin in pedal is a couple of mm higher than the brake one..
a couple of mm can make all that difference?? I'll be a monkey's uncle if that's it! :D
PostPosted: Sun Jul 17, 2005 8:23 pm
Anton,
That's a couple of mm (maybe 3), x the pedal ratio- probably becomes 1/2 an inch pedal height... :shock:
PostPosted: Sun Jul 17, 2005 8:58 pm
that much?!? :shock: far out!! There is a lesson for all I reckon!!
I have learnt sooo much during this resto....I could never stray from Mini's now will all this knowledge!
Users browsing this forum: No registered users and 120 guests
