What carb needles are in it? I would try Ms to start with...
If it dies when warm and won't restart until cool, check the valve clearances are not closed up.
Thanks Doc, I have M needles in there now, with red springs.
I'll check the valve clearances, hadn't thought of that one, They were set to 15 thou cold, by the 'longer' rule of nine method in the manuals...
I'll check the flywheel straps too. I could've sworn i did them up right but....
.... I have been known to make mistakes. (at least I learn from them tho')
Circus_Maximus; There are no locating rings, as it is a maniflow manifold, but when fitted it locates on the studs. Looking down the ports, it is a perfect match!!
No servo takeoff, and the vac advance line is good. There is some play in the carb spindle bushes, so maybe there is a vac leak here? i'll get them sorted soon too.
FatMaserati; Yeh, the engine mounts & steady bushes all new. It doesn't move at all, (it's not visible vibration, like where the steady rubbers are gone, I got that on my 78 van
) it vibrates. like you put your hand on an .. um.. vibrator? But a big one!!
Kind of like when holding an angle grinder.
Thanks all, I'll check up on these ideas this weekend, & if you have any more keep em comin!
I'll let you know how I go
Matt
