It is currently Sun Aug 03, 2025 12:00 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 07, 2005 8:24 pm
Ive got a sort of arrow head thing so it wont damage it but yeh matbe for next time doc
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Tue Jun 07, 2005 10:48 pm
Just use a bigger FBH(navy speak for F&$king big hammer!!). I had a flywheel come off right when I least expected it to - shot clean across the workshop I was in and nearly clobbered Dads heeler 10 feet away. Hindsight is a wonderful thing and is funny as heck when I look back. The SCA flywheel puller has done 11 flywheels now without a hitch so I must be very very lucky!!
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Jul 16, 2005 8:08 pm
ok guys im in the same boat here and so far have stripped 3 high tensile bolts, went out bought an oxy kit tried heat and new bolts and am turning the puller with a 3 foot breaker bar and it dont want to budge am starting to think i need a hydrolic puller either that or im gunna cut the damn thing off (this is the spare doner motor)
any other ideas???
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
PostPosted: Sat Jul 16, 2005 8:53 pm
What you need to do is get someone turning it while you hit the flywheel with a hamer and that is how we got ours off
My 2c (from past experience)
Pat
PostPosted: Mon Jul 18, 2005 9:49 am
Never never never hit the flywheel with a FBH or a hammer of any weight, size, colour, race, religion or whatever - but you can use a block of wood and your trusty hammer through the starter motor hole - few taps then rotate the flywheel a little - few more taps then rotate more etc etc etc. Get the picture :lol: Then, you can put a bit more "oomph" on the puller and repeat the whole process 'till the flywheel drops off into your hands and doesn't shoot across the room killing poor Fido in the process.
Rod Image
PostPosted: Mon Jul 18, 2005 10:24 am
Wot he said... ^
Flywheels are cast iron, which is brittle stuff. Doesn't like being hit with BFH or VBFH.. :cry:
If you crack it and it later goes BANG at high revs, guess where the bits go... :oops:
I would add if your flywheel puller won't get it off without being bashed, you need a stronger puller.. :wink:
Users browsing this forum: Bing [Bot] and 78 guests
