It is currently Sun Aug 03, 2025 2:21 pm
 Post subject: STGGERED PISTONIES
PostPosted: Mon Jul 18, 2005 10:34 pm
ok i was talking to a mte last nite down at the pub, he told me that hismate has a 1275 or something of that caliber, stroked out to close to 1400, now this is what i want to know .... he said the pistons were "stagered" meaning (this is how he explained it) that the pistons are not lined up in a row, they are stagered
eg: 4 pistons
one closer to the top, the next one closer to the bottom, then top, then bottom
wouldnt this mean that the conrods would ahve to be at a angle to connect to the crank
it sounds like some bs to me
but would be interesting to know if its possible
cheers steve
J E N N I F E R G A R N E R
Hmmmmm..... Jennifer Garner
PostPosted: Mon Jul 18, 2005 10:38 pm
Could be "Pub Talk" or it could be off-set boring...
Anyone else wnat a go ?
J
PostPosted: Mon Jul 18, 2005 10:41 pm
hmm yeah .... explain off set boring :)
PostPosted: Mon Jul 18, 2005 10:57 pm
pic kinda tells the story
you can squeeze bigger cubes in there
except you probably wouldnt want me to bore your block like that
Inconspicuously Conspicuous
PostPosted: Mon Jul 18, 2005 11:00 pm
yeah thats it so that off set boring then is it ?
alright ... how does that work does the conrod have to be angled cos the crank would still be straight.... /steve confused
PostPosted: Mon Jul 18, 2005 11:03 pm
mainly you would need a not-so-normal crankshaft
the conrods wouldnt really need to be special unless it was severe
PostPosted: Mon Jul 18, 2005 11:15 pm
You can, instead of going front-to-back-to-front-, go further away from each other, so you push them to eac end, but, again, your crank will have to be changed... Sounds ex$pen$ive :(
PostPosted: Mon Jul 18, 2005 11:20 pm
I've never seen it done duc's way :lol:..probably a good thing :), only where they are seperated to give room for larger bore.. ie 1 & 2 and moved towards the radiator 3&4 towards the flywheel...with a bit more spacing..not sure about crank mods..
PostPosted: Mon Jul 18, 2005 11:34 pm
No crank mods are needed for `offset boring'. There is room for the pistons to slide on the gudgeon pins- the bores are not moved far.
Reason for doing it- on a 1275, 2&3 are closer together than 1&2 or 3&4.
Why? Buggered if I know! :lol:
If bored at normal spacing to 74mm (1400cc - for which pistons are now unobtainium) there is too little metal there, it's getting a bit close... :cry:
<edited> for clarity
Last edited by drmini in aust on Tue Jul 19, 2005 7:14 am, edited 1 time in total.
PostPosted: Tue Jul 19, 2005 3:34 am
VW does that for their narrow angle V engines, I think you'll find that they need to be bored at angles like a V engine.
Either way I reckon your mate might be a bit pissed while trying to explain the offset pistons mentioned by previous posts. A mate of mine who is a genius engine builder was explaining that to me once and for a little while I got the impression that they had been staggered the way you describe, until he put me right
PostPosted: Tue Jul 19, 2005 7:16 am
Offset boring is explained in Vizard's Yelow Bible, done for the purpose of maintaining max meat between 2 & 3. Can be done as Mini Mad says or for really big bores the centreline is also moved slightly toward the push rods holes.
Steve
PostPosted: Tue Jul 19, 2005 7:24 am
Steve, big pistons are getting a bit scarce now, I haven't seen 74s for years..
Many people now bore to 73, keeping 73.5 up their sleeve for later.
And you don't have to offset to get to these sizes. :wink:
PostPosted: Tue Jul 19, 2005 1:30 pm
My 1430 is offset bored.
Jonathan
