It is currently Mon Aug 04, 2025 3:25 am
 Post subject: Mk1 and Mk2 bodies
PostPosted: Tue Jul 19, 2005 8:34 pm
Can anyone tell me why you would have a 3/69 Mk1 with a Mk2 body ? Also, what is the difference between the two ? Came across some very interesting information, that's got me baffled.
Thanks for your help.
Brendan
PostPosted: Tue Jul 19, 2005 8:51 pm
Most of 69 production was the `MK2' body, from what I have seen- it depends though on your definition...
I call it when the wipers changed to LH park, with recessed shaft thingys.
Happened in 1968, sometime.. :lol:
As for Cooper S there was so-called Mk1 and MK1-1/2, and MK2 but the factory never called them that.
From a global perspective, all out Minis are MK1 (external hinges, small rear window).
PostPosted: Tue Jul 19, 2005 9:01 pm
I have a few people helping me out researching my car body numbers. They sent me a message stating my car number is a 3/69 Mk1 with a MK2 body. They haven't seen the car and I haven't as yet been able to contact them. The suspense is getting to me and I was wondering if anyone knew why an ID Mk1 would have an MK2 body ? They are only going off past mini records. :?
PostPosted: Tue Jul 19, 2005 9:05 pm
could have been swapped over?
PostPosted: Tue Jul 19, 2005 9:09 pm
The Oz records are nowhere near complete from what I have heard. BL left for UK in a hurry... :cry:
If it's an S, PM `Graham in Aus' on here, he can probably help you. :wink:
PostPosted: Tue Jul 19, 2005 9:13 pm
What do you mean swapped over ? The person I have researching the numbers has never seen the car, he wouldn't know if it was a Mk2 body or not. Someone once told me a lot of left over Mk1 parts went into early Mk2's but why would it still be ID as a MK1 if that was the case. :?
PostPosted: Tue Jul 19, 2005 9:15 pm
Thanks mate, I'll do that :wink:
PostPosted: Tue Jul 19, 2005 9:17 pm
Not long after yours was built, they stopped fitting BMC body ID plates.
Cars built in mid 69 had no plates.
VIN plates came in at end of `69. My 3/70 car has that.
PostPosted: Tue Jul 19, 2005 9:18 pm
well with my car its part deluxe and mini K.... its actually a late deluxe but with the mini K wiper indents..
maybe its similar for u?
i was thinking the Plates could have been swapped over? :?
PostPosted: Tue Jul 19, 2005 9:27 pm
Sounds too me like you may have a Mark 1 1/2 as the doc mentioned.
They have some of the Mk2 bits but things like the front badge being the older one for an
example.
I hope its as simple as that for you as your car (going by your post about the engine numbers) is having an identity crisis.
I hope its not a bitsa for your sake.
Unit
Cooper S Mk 2
PostPosted: Tue Jul 19, 2005 9:56 pm
example.
Unit
I really do hope it's a Mk1 1/2 as well and not a bitsa. I also wonder if I did do the right thing. Still I could probably get around the purchase price if I pulled it apart. :cry:
PostPosted: Wed Jul 20, 2005 8:45 pm
Don't confuse build date with first registration date.
Does your car have the ID plate fixed to the firewall behind the clutch master cylinder? If so it's a MK 1 or 1.5. There is no way of establishing an exact build date prior to the end of 69 when ADR plates were introduced.
The later type wiper panel was introduced in early/mid 68 and was used on late Mini Deluxe and MK1 Cooper 'S' cars, the so called Mk1.5 cars, Like mine, and continued through to the end of production in 78.
The interior trim is identical on Mini Deluxe and MK1 Cooper 'S' cars (apart from floor covering) and there are 2 types. The 2nd type was introduced at the same time as the wiper panel change. The first type was the same as 997/998 Cooper cars and was used in the Mini Deluxe and Cooper 'S' cars prior to early/mid 68.
Mini K and MK2 Cooper 'S' cars use the same trim but it is different to the 2nd type Mini Deluxe- MK1 'S' trim in both style and material.
I don't believe there were any MK 1 Cooper 'S' cars built in 69 as you couldn't buy one in your preferred colour until May when the MK 2 went on sale. Any MK 1 cars bought in early 69 would have been built in 68 and you had to take whatever colour was in stock at the time. I bought mine in Jan 69 and the colour choice was very limited.
Don't know if it helps but that's what I remember from 69. Others may disagree.
Regards
RonR
PostPosted: Wed Jul 20, 2005 8:49 pm
Ron, you continually amaze me- your memory is like a steel trap! :lol:
We would be lost without you. :wink:
Kevin
PostPosted: Wed Jul 20, 2005 8:55 pm
:D
Hi Kevin,
It helps to have owned from new an early and late MK1 'S' as well as a used MK2 and a Clubman GT. Apart from Minis it seems I have KRAFT disease for most other things, according to my wife. Maybe it's just domestic oldtimers disease? They say you only remember the things you really like.
Regards
Ron
PostPosted: Wed Jul 20, 2005 9:38 pm
Thanks mate, I'm greatful for the information even though it confuses the issue more. I' ll post whatever information I get, when I get in contact with the person helping me research my car. I talked to Graham ( Graham in Aust ) as some people suggested and he thought the numbers I gave him were consistant with a build date of 3/ 69. I'd really be interested in any comments you have when I find out more. :wink:
Brendan
Users browsing this forum: Fritzie and 98 guests
