It is currently Mon Aug 04, 2025 1:40 am
 Post subject: Double gaskets
PostPosted: Thu Jul 21, 2005 9:28 am
I have a sealing face that is a little worse for wear. It's where the heater pipe bolts to the cylinder head (on the drivers side).
The heater pipe flange was rooted, but I cleaned that up with a flat file. The face on the head is a little corroded....and this I can't change.
I put 2 gaskets between the flange and head. Is this acceptable? Or will this leak?
It was leaking with a single gasket. :x
 Post subject: Re: Double gaskets
PostPosted: Thu Jul 21, 2005 9:35 am
Not sure if a 2nd gasket is going to help. You might get away with a gasket & some RTV silicon on each side though.
How deep is the pitting?
PostPosted: Thu Jul 21, 2005 9:40 am
hmmm...my theory was that the double thickness would help squash into the pitting to create a seal.
The pitting isn't deep, but it's no 'flat face' :( I can only speculate about the depth.....at a guess maybe .005" - .010"
PostPosted: Thu Jul 21, 2005 9:49 am
Is this on JAM? And the head's just been all painted and looks yummy?
Because I was going to suggest a better way to go is to get the pitting brazed up and machined flush. What a PITA huh :?
PostPosted: Thu Jul 21, 2005 10:02 am
What about building up the mating face with some DevCon ?
(Engineering supplies....)
should be heat-resistant to about 1700'f ........
you can file it, shape it, whatever.... just give it enough time to go-off ...
Its what i did with my Thermo housing on the last 202 head i used.... hasnt leaked since...
J
PostPosted: Thu Jul 21, 2005 10:14 am
High heel ninja
Anton, give it a go with 2 gasket & some silicon, i had the same problem on Pen's Clubman it worked on it.
Doogie
PostPosted: Thu Jul 21, 2005 10:44 am
as of last night I have put 2 gaskets with copious amounts of Loctite #4 gasket goo. I am hoping the hard setting goo, plus the 2 gaskets will be enough.
In theory I should have looked at this when the head was stripped bare.... :x I could have had that face machined........ :roll:
Devcon will be the alternative I think. Heard about it years ago....never used it (yet).
Cheers for the feedback guys.
PostPosted: Thu Jul 21, 2005 7:41 pm
:idea: Bend the tin flange up a bit at each end, it's probably bent the other way from over-tightening. :lol:
I uas Loctite 515 Master gasket on all the water joints now- it's magic stuff. Would want to be for $18/tube, hey. :wink:
PostPosted: Thu Jul 21, 2005 10:24 pm
It's $25 a tube west of blacktown!
But it is good stuff I'll agree.
PostPosted: Thu Jul 21, 2005 10:27 pm
It's also the reason my gearboxes don't leak. For a while, anyway. 8)
PostPosted: Fri Jul 22, 2005 8:29 pm
well...the double gasket and Loctite #4 sorted me out. Took JAM for a rap this afternoon and no leaks :wink:
mmmmm.....sniff sniff....you smell that?? I can smell rego :mrgreen:
