It is currently Mon Aug 04, 2025 6:03 am
PostPosted: Fri Jul 22, 2005 9:56 pm
Put it this way Camel, your car now stops! I think that's priceless! :wink:
Lillee - 1969 Morris Mini K
PostPosted: Fri Jul 22, 2005 10:59 pm
Namibian CAMEL wrote:
brakes really give you so much more freedom while driving, its unbelievable also. Driving with no brakes is so very restricting and annoying,
:wink:
:roll:
Chris
Everything I like is either
PostPosted: Sat Jul 23, 2005 9:25 am
you saved $120 for a wheel alinement :shock: can you choose which celebrity does it for you? :)
GTi Turbo'd mini, abused daily
PostPosted: Sat Jul 23, 2005 9:58 am
You said you didn't know what a sleeve does.
Well the master cylinder is exactally that, a cylinder. There is a piston that moves up and down inside the cylinder. Now this causes wear on the cylinder wall, so you bore it out, and put a sleeve in there so that the cylinder wall is all new again!
PostPosted: Sat Jul 23, 2005 1:38 pm
yeah thts what mine probably needs.
yeah scotty, it is the twin system, how did you know that? is yours the same? or have u been perving on my mini??????
78 Leyland Mini - Prince
PostPosted: Sat Jul 23, 2005 1:41 pm
It's the same as mine, and Pete was telling me about your problem. He shown me the shiney spanking new spacer drums you got, too.
PostPosted: Sat Jul 23, 2005 1:55 pm
yeah and they do SFA cos my master cyl is rooted :(, i have to pull them off and [aont them, i think thats a job for sunday
PostPosted: Sun Jul 24, 2005 10:56 am
here me thinks no lights. i even today after picking up mini ask a bloke at the servo if i had lights and no i didnt. BUT when i reverse into the shed today, back up to wood, there is brake light glow. the brake lights only work when car is on, and the rego blokes didnt know that. Yet they would fail me for it Shocked ??
but that was strange
Camel, the reverse lights (some minis have them) are in the same area or what have you as the brake lights so if you have your mini in reverse it might look like you have brake lights.
Take the lens off and check the globes, if your lucky it might be just globes otherwise start looking for loose or broken wires, also check the contacts between the globes and the socket they are sometimes dodgy. :wink:
Roads need more corners
PostPosted: Sun Jul 24, 2005 6:30 pm
What fuzzy is trying to say is that the indicators act as your reversing lights, but instead of flashing, they are both constantly on. :wink:
PostPosted: Sun Jul 24, 2005 9:33 pm
teh admin God
teh admin God
that only come one when i press the brakes? the reverse lights??
i was stationary when pressing brakes and they then flashed on and off.
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
Users browsing this forum: Bing [Bot] and 103 guests
