It is currently Fri Jul 18, 2025 11:36 am
 Post subject: Box Time
PostPosted: Sun Jul 25, 2004 7:03 pm
Okay guys I need a new Box.
What do I look for of course I want a full syncro.
Additionaly its going on to a 1100+60 and a 731 cam and atisipating a Graham Russel 202 head upgrade.
What box and has anyone got one that will be worthy
PostPosted: Sun Jul 25, 2004 8:03 pm
Mini-K box. Remote, not rodchange- so it doesn't try to imitate an 850 one and climb out of the car!
If you want MK2 S ratios, go buy an S 1st motion shaft and cluster- that's all it needs. :wink:
ping kazjim, he has some, real cheap! Gareth_1330 got one today.... :P
PostPosted: Sun Jul 25, 2004 8:21 pm
Thanks Heaps Dr once Again
I'm am not to worries about cheap :shock: This Is Morris and what something that will last in Sue's mini. What should I look for in a good Gear box that will last and possible give a little more performance.
Also a PM Sent
PostPosted: Sun Jul 25, 2004 8:25 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
doc i have these 3 boxes what are these
22g846
22a1288
22g1832
makka
PostPosted: Sun Jul 25, 2004 8:31 pm
1st one I dunno...
22A1288 is listed as 850/998 magic wand..?
22G1832 is rod change, small idler (not A+)
:wink:
PostPosted: Sun Jul 25, 2004 8:37 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
thanks kev
makka
PostPosted: Sun Jul 25, 2004 8:47 pm
jees kev mate you should make your own help section in this forum, ask Doc or somthing, lol i want all your knowlege please :) hehehe
GTi Turbo'd mini, abused daily
PostPosted: Sun Jul 25, 2004 8:55 pm
All hail the Dr
PostPosted: Sun Jul 25, 2004 10:09 pm
Yeah! i almost bought two.... now i need to find a S 1st motion and cluster for the right price.. Hah!
Thanks Kazjim ;-)
PostPosted: Mon Jul 26, 2004 10:45 pm
er.. I got one of each.. :wink: but they came out of a gearbox that the idiot PO ran out of oil. Cluster needs its bores grinding and bearing sleeves fitted. Hardly worth the trouble. Ist motion shaft not perfect inside either, really needs the same deal, or grind out for the larger 18mm mainshaft bearing (used on later rodchange).
Know someone with an internal cylindrical that will work for nix?? :roll:
PostPosted: Tue Jul 27, 2004 10:05 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
kev when i pull the motor of the box could i get you to look it over and tell me if any thing needs replaceing cos i'm going to rebuild the cooper motor
makka
PostPosted: Tue Jul 27, 2004 7:43 pm
No problemo. :wink:
PostPosted: Tue Jul 27, 2004 11:21 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
sweet i may be going with jim to see kaz if it is cool with him
makka
