It is currently Mon Aug 04, 2025 3:25 am
PostPosted: Wed Jul 20, 2005 6:30 pm
I just want to remove the old thick yellow paint on my horn (in my quest to remove all of the last yellow items under my bonnet). I want to paint it the same black as my engine. I have removed most of the old paint by hand with a blade, but some nooks and crannies need to be cleaned out with some kind of paint remover.
Can anyone recommend a good paint remover that might do the trick?
Jonathan
PostPosted: Thu Jul 21, 2005 12:41 am
just walk into a hardware store and ask the guy there he should have one he reccomends...i recon the'd all do the job pretty much
PostPosted: Thu Jul 21, 2005 1:13 am
or use a little brake fluid if its only a little area.. it worx well!
-Cam 8)
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Sun Jul 24, 2005 1:34 am
or just sand back the old paint
PostPosted: Sun Jul 24, 2005 1:36 am
any paint stripper show do the job
 Post subject: Cheap as
PostPosted: Sun Jul 24, 2005 6:58 am
If you have an engine reconditioner near by drop down these and ask them to run their sandblaster over it. A 2 min job and the surface will be ready for paint and it will bind to the surface well!
Or
Use thick black paint and just paint over the yellow. If you have sanded the rest off I'm guessing the edges of the remaining paint is feathered so you wont see the transition from metal to old paint through the black.
PS
Fitting a modern horn I recon saves a heap of space and weight. The Mini duel horns a bloody heavy
PostPosted: Mon Jul 25, 2005 12:41 pm
Small wire wheel on a drill ( + EYE PROTECTION like gogles) it cleans anything to bare metal. Ideal where an angle grinder wheel is too big.
PostPosted: Mon Jul 25, 2005 1:05 pm
I agree with mike on that one, boy does it work well! so be careful :lol:
Lillee - 1969 Morris Mini K
Users browsing this forum: Fritzie and 84 guests
