It is currently Fri Jul 18, 2025 11:33 pm
PostPosted: Tue Jul 27, 2004 8:26 am
Hey all, I've worked out why I'm having troubles with my LH Brakes (Keeping seals up to the calipers... )
It appears that when i bolt the caliper up tp the hub, it isnt sitting square.... and on closer inspection, it seems that the "ears" on the hub are actually bent towards the disc !!
Its only about 0.030", but still I'm not happy with it....
So, Repair ? Replace with Stock ? Convert to Honda ?
hhhmmmmmm
J
PostPosted: Tue Jul 27, 2004 8:43 am
you should be able to find another hub without too much trouble...and all mini disc brake hubs (except the cooper 7") will be the same. It is only the calipers that are different. :wink:
Try one of the importers...or a 'wanted' add.
Minimad
Ps. Get the correct side though :shock:
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Tue Jul 27, 2004 9:27 am
Sell em to me! and get hondas! :wink:
Lillee - 1969 Morris Mini K
PostPosted: Tue Jul 27, 2004 12:58 pm
hhhmmmmmm
J
hey mate , do u think that happened on the way home from wakefield ? cos that would have put huge strain on the caliper brackets, imo go the honda setup ;)
lookin for another clubby
PostPosted: Tue Jul 27, 2004 1:23 pm
Its possible, but I remember when i first fitted them, that the caliper was close to the disc, so I made up some spacer washers and used it like that for over a year.....
Its been a while, so I'm not in a great hurry to fix it, but I'm just starting the process.......
Anyone Got a LH Cooper "S" Hub for sale ?
J
PostPosted: Tue Jul 27, 2004 2:05 pm
hey james,
There arnt many hubs floating around anymore mate, remember when i was looking for some, took me 12 months to find a pair :shock:
You can sometimes find them on UK ebay for around 20 pound a pair, or brand new hubs from minispares aus direct for around $120aus each.
brad.
1974 Moke - 998cc
PostPosted: Tue Jul 27, 2004 7:29 pm
Put it in a lathe, reface the lugs. Easy peasy. If only out .030" you won't even need to shim it. :wink:
PostPosted: Tue Jul 27, 2004 10:55 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
easy peasy he sez lol for you what about us mere mortals :)
makka
