It is currently Wed Aug 06, 2025 7:04 am
PostPosted: Wed Aug 03, 2005 2:52 pm
Hi Guys.
I have an 1100 with a 12G295 head. twin 1 1/4 su's.
What sort of extractors should I get? Keeping in mind I may one day want to supercharge and or get an 1275 going? Is there a type of extractor that can handle all those applications?
Do I put the extractors on before I drop the engine in. I would imagine they are hard to get on once the engine is in...But I am also concerned that the engine would be hard to get in if there are large extractors hanging off the back.
I assume heads exhaust outlets are similar?
PostPosted: Wed Aug 03, 2005 3:03 pm
if you are really against buying new extractors when you got to a 1275.... get some big bore LCB's....
other wise... buy the small bore lcb and go the the large bore when you're dropping the s/c or 1275
PostPosted: Wed Aug 03, 2005 3:46 pm
LCB for sure!!!
I love the sound they give :wink:
PostPosted: Wed Aug 03, 2005 4:01 pm
Big bore LCB 8)
easy to fit with the engine in
PostPosted: Wed Aug 03, 2005 4:03 pm
I would just buy these: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... =WDVW&rd=1
The do all and end all of all LCBs I reckon
Is it way too difficult to get the engine in with large bore LCB's on?
How far back do they go? Where can they be disconnected?
PostPosted: Wed Aug 03, 2005 4:11 pm
i don't mean to be picky on my first post, but you probably mean the be all and end all...
you are right, however :)
PostPosted: Wed Aug 03, 2005 4:20 pm
Yeah typo :oops:
Can be disconnected from the dump pipe I'm pretty sure, if it is clamped that is. There's quite a fair bit of room to work with...
PostPosted: Wed Aug 03, 2005 4:57 pm
Depends where the join is in the system, i remove the extractors and hook it back up once the motor is in. Don't risk damaging the paint as much that way.. Just unbolt them from the head.
