It is currently Mon Jul 07, 2025 2:12 pm
PostPosted: Wed Aug 03, 2005 7:18 pm
gday everyone
few questions i hope you can answer.
say if you are putting a non mini motor into your mini, with the sub frame, would you leave the standard mounting points for the top of the shock, and top and bottom control arms and caster rod? or would you have to fabricate all new points into the new sub frame. if so, how would you get everything in the right place again?
how would you get the motor sitting in dead straight in the sub frame?
Hope I asked the question in the right way, sorry if this has already been answered, please post the link!
many thanks, josh
PostPosted: Wed Aug 03, 2005 9:18 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
josh they use the original pick up points for the suspension and the castor arms just cut the subframe to mount everything else
makka
PostPosted: Thu Aug 04, 2005 12:24 pm
makka
ahh ok, thanks for that. makes things a lot easier to understand now :D
but in regards to getting the motor sitting right, how would you go about that?
PostPosted: Thu Aug 04, 2005 2:13 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
you need to take messurements front to back side to side then across from the back left to the front right and the back right to the front left so when you cut it to allow the motor to fit you dont lose the squar if you know what i mean
PostPosted: Thu Aug 04, 2005 5:39 pm
to get mounting position for the motor line up the driveshafts as close as possible to dead centre of the hub.
1974 Moke - 998cc
PostPosted: Thu Aug 04, 2005 7:40 pm
Yeh don't make it crooked like that crook(ed) roundnose + 4EFTE in Perth... :lol:
PostPosted: Thu Aug 04, 2005 8:28 pm
O man that one was a shocker... :lol:
 Post subject: String line
PostPosted: Fri Aug 05, 2005 7:09 am
On mine I'm using a string line to get the centre of the hubs and a B&D laser line to align the drive shafts, I've also measured the height level but this is harder to get but maybe not so critical it also depends on the wheel size and final ride height you want.
Measure, measure, remeasure, get confused, have a beer and start again.....
hehehehe
