I like Dellortos, but parts are harder to get.
Mine is a 45DHLA, dunno what it's off- was on the car when bought.
Most I've seen lately are 40DHLAs off Alfas with 33mm chokes.
I have 2 of these, so far I've jetted one as per Des Hammill for our 1132 Clubbie but not run it yet. Des says the pre-emission ones are better but they are all scarce now. The emission carbs have an idle bypass circuit and more progression holes, similar to Weber.
For competition most people close off the idle bypass by screwing the adjusters in.
I recommend anybody running a Weber or Dellorto should buy Des Hammill's book- "How to build and power tune Weber & Dellorto", available from
www.pitstop.net.au and elsewhere. It has a wealth of info and explains it all well. I have a few other Weber & Dellorto books, but this one kills them.
I've run a 45DHLA for 9 years on a 1310, seen no unusual engine or gearbox wear. `Bore washing' you read about won't happen unless it's poorly jetted.
<edit> Just don't pay silly money for these things. I've seen a S/H 40DCOE on Redline manifold going for $700 or so... sheesh!
Same manifold is worth about $120
new at Mini Classic.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
