It is currently Sat Jul 19, 2025 5:24 pm
 Post subject: cutting a manifold
PostPosted: Mon Aug 08, 2005 4:01 pm
How hard is it to cut a manifold to make it suitable for extractors? I'm thinking 1 3/4
How do you do it?
PostPosted: Mon Aug 08, 2005 4:39 pm
Get a hacksaw or angle grinder, cut the exhaust part off without damaging the inlet.
Then, grind the remains off the bottom of the inlet so it's sort-of smooth. If you go too far you can braze it. :lol:
When buying extractors beware. Some UK ones (like Maniflow LCB) won't fit. Most of the Oz ones- Perry etc do, the middle pipe goes down at an angle to clear the inlet.
1-3/4" eh... you would do better to buy a MiniSpares or Graham Russell manifold that flows, IMO. The stocker is just OK with a 1.5 carb. :wink:
PostPosted: Mon Aug 08, 2005 4:44 pm
Are those mini spares manifolds okay?
What is with the water flow? is it to warm or cool? What benifit is there? Do you just pipe it in series with your heater?
PostPosted: Mon Aug 08, 2005 4:48 pm
You're in Orstraylia, maaate.
It's to warm it...
Most people don't bother to hook it up, unless they live in Can-Bra, Goulburn, the Snowy or new England....
Yes the MiniSpares one is supposed to flow OK. But the GR one is better, and made here in Oz.
 Post subject: Oi!!
PostPosted: Mon Aug 08, 2005 6:21 pm
Nah ...in Canberra we don't bother either....we have Minis that run hot here just like everyone else :D
Then again, Penalurick runs a perspex grill blanking sheet ALL year round!!!
PostPosted: Mon Aug 08, 2005 7:16 pm
I have the same problem. i have a set of extractors waiting to go on to my engine but i dont have a new manifold. so can u just cut off what gets in the way and braze in a peice of steel plate to seal the manifold???
by the way im am running a 1 1/2 SU on a 998
PostPosted: Mon Aug 08, 2005 7:21 pm
You don't have to braze plates in usually. At least if you're running an Oz made LCB or 3-1, they miss OK.
There's about 3mm of metal there, between inlet & exhaust....just don't cut through it.. :lol:
Users browsing this forum: No registered users and 67 guests
