It is currently Sun Aug 10, 2025 12:36 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Mon Aug 08, 2005 5:14 pm
OK Barney's 1293 is not going bad, but he's a bit lean between idle and 3500rpm. From there to 7000 it's all go-go-go.
Cam is a Tighe 104, he has ToyoMini (ie Corolla) 1.46:1 rockers & rimflo valves.
Needles in now are #6. I has CP4s in but the #6 are better up high.
So, all you guys with a Fuzzpack Cooper S, what needles are you running? :P
Greig Malaure says I may have to get the file out. I have some `needle files'.. :lol: :lol:
PostPosted: Mon Aug 08, 2005 5:23 pm
no idea off the top of my head. I know the ones that were in them before had been filed down.. I have given up on twins.. never again :lol:
PostPosted: Mon Aug 08, 2005 10:54 pm
give Bill Silvertsen a Call (Silvo) at Midel Dr
PostPosted: Tue Aug 09, 2005 12:53 am
Haven't quite finished rebuilding my HS4's for my 1275A+ plus.020 but I am putting in BG needles to initial start with as I am told these are the basic COP needles they used.
68 Deluxe. All the Options and Mods. Bling-Bling.
PostPosted: Tue Aug 09, 2005 7:00 am
Karcraft told me it was CP4s they used...??
I know there was some needle confusion at the time....
Vizard suggests #3 or #4.
I think I'll try #3 next, as I have a pair. :wink:
PostPosted: Tue Aug 09, 2005 9:56 am
Hey kev...
You could try any number of these needles,,,they all will produce a richer bottom end than the CP4s or MMEs or #6 type needles
AS
CS1
FG
P6
R6
RLB
RLS
we can fine tune things over the net after all mate :-) :-) :-) :-)
easy-peasy :-) :-) :-)
PostPosted: Tue Aug 09, 2005 12:59 pm
Has any body tryed this program I have downloaded it but not sure how accurate it would be it lets you put your mods in and gives you a suggested needle size.
http://www.winsu.co.uk/
I swerve and hit people at random.
PostPosted: Tue Aug 09, 2005 2:01 pm
Yeah I have and It worked a treat and Still have not quite found the correct one for my HIF as it still lean down low and lacks the torque. The othere needles all have a richer top end and I do not want it any richer up there.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Fri Aug 12, 2005 8:24 pm
OK Barney finally got his problem sorted today with the help of GR's fuel/air meter.
His #6 needles in the HS4s were spot on.
It was actually going real rich (reading around 10 or 11) between idle and 3000 rpm, as the 20W/50 oil was restricting the SU pistons from rising.
Drained the oil out, he's running fine now, with NO damping at all... 8)
PostPosted: Fri Aug 12, 2005 8:37 pm
OK at the risk of sounding like a dick :oops: is a HS4 the same as a 1' 1/2 su or 1" 1/4 :?:
Or is not a SU at all.
 Post subject: Needle Files
PostPosted: Fri Aug 12, 2005 8:42 pm
Just when I was gunna donate my old needle files to use....he sorts it out :shock:
I won't ask why the twenny dubya fifty was in their Doc....somethings ya just don't ask :lol:
We have a member here with an ex-Police Cooper S MKII....I will try and find out what needles he is running (may be a lost cause after all these years...most probably fiddled with) :roll:
PostPosted: Fri Aug 12, 2005 8:45 pm
Doorlady, an HS4 is an SU, 1-1/2".
Mick, I put the 20W50 in... had to start somewhere. No flats spots now with them empty, so it can stay like that for a while. :wink:
PostPosted: Fri Aug 12, 2005 8:56 pm
what springs are you running with that set up Doc?
PostPosted: Fri Aug 12, 2005 8:58 pm
Buggered if I know, Matt. Paint on end all gone..
Graham said they are working OK so leave in. :lol:
PostPosted: Fri Aug 12, 2005 9:00 pm
no damper oil?? wtf??
Users browsing this forum: Bing [Bot] and 92 guests
