It is currently Wed Jul 23, 2025 6:27 pm
PostPosted: Tue Aug 09, 2005 10:10 am
This is perhaps the stupidist question anyone has asked here.
Where does the heater connect to the engine cooling system.
I know one of the connectors is to the weird looking bottom radiator hose. Where does the other one connect?
Sorry for my ignorance :oops:
PostPosted: Tue Aug 09, 2005 12:07 pm
straight back into radiator if its there, otherwise I'm stumped too :shock:
PostPosted: Tue Aug 09, 2005 12:20 pm
One end connects to the bottom hose. Late Aus built Clubby and Moke have a metal pipe leading to the bottom radiator tank instead.
The other hose connects to the top of the cylinder head at the clutch end. If you car has never had a heater before, there will probably be a small plate there held on with two nuts. Replace the plate with an elbow or heater tap, depending on preference.
Some A+ engines don't have the heater port drilled out on the head. In which case you will have to drill it before you can fit the elbow. Stud holes should already be there. :wink:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Aug 09, 2005 1:34 pm
ahhhh. I thought I remembered something like that.
I put a 12G295 head on and it doesn't have the elbow coming off the head. Hopefully I have one from the old head.
Users browsing this forum: No registered users and 119 guests
