It is currently Sun Aug 10, 2025 2:47 am
PostPosted: Wed Aug 10, 2005 8:07 pm
I don't need one right now, but may have need one soon/eventually/who knows? It would be nice to know where the nearest one is
Ben
PostPosted: Wed Aug 10, 2005 8:43 pm
Make one. :)
It is not hard, you just need a master cylinder or a grease gun! (I prefer the master cylinder) and a high pressure hose and fitting.
PostPosted: Wed Aug 10, 2005 9:11 pm
Didn't know that you could!
Cheers, I'll have to find some time and make one.
PostPosted: Wed Aug 10, 2005 9:35 pm
Make one. :)
And a lever so you can get decent pressure... :wink:
Here's mine- clutch MC mounted on an upturned Fiat 124S pedal box.. 8)
Last edited by drmini in aust on Wed Aug 10, 2005 9:45 pm, edited 1 time in total.
PostPosted: Wed Aug 10, 2005 9:38 pm
This link might be a good place to start if you want to make one yourself (grease gun style but you can substitute a master cylinder) ...
http://members.cox.net/oldertech/hydrolastic.html
If you are not so keen on making one ask around I was surprised to find two within reasonable reach of my home town so there are some around, maybe... :oops:
Roads need more corners
PostPosted: Thu Aug 11, 2005 3:58 am
I was trying to, I don't mind making one, but for the one or two times I'll ever use it I was hoping to find one nearby. I can appreciate though that there won't be many in WA so I'll probably make one 8)
PostPosted: Thu Aug 11, 2005 12:03 pm
You might need to use it more often than you think!!
Whenever a subframe comes out, changing upper suspension arms or pins, or knuckle joints, if a hydro bag gives out (as they do sometimes), if the lines get rusted, or if you are just wanting to change the fluid. You would be amazed at the amount of rust in (mostly) 30+ year old hydro fluid.
Well worth the efort I reckon!!
I made one from a grease gun, it takes a little while, but you have good control. (15-20 minutes per side from completely empty.)
Matt
