It is currently Sun Aug 10, 2025 12:22 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: su
PostPosted: Thu Aug 11, 2005 12:40 pm
just a quick note for those with SU's pumping the throttle does nothing except make you feel better, they don't have accelorator pumps so all your doing is openimng the throttle butterflies, cold start with SU's rely on the choke.
PostPosted: Thu Aug 11, 2005 2:38 pm
i just finished reading that whole thread and was just about to say the same thing..
pumping the throttle on a SU does nothing.. flaps the little butterfly around and thats it..
webers(most other carbs actually) have a lil diaphram which squirts some petrol in when you pump it..
no point on an SU
Expert in training
PostPosted: Thu Aug 11, 2005 2:42 pm
JAM
Not a common twin SU issue I would be looking else where like the distributer.
Was it totally rebuilt, is it the right one for the car or modified or from another car entirely, whats the shaft like, have you put in another distributer and tried that?
steve
PostPosted: Thu Aug 11, 2005 4:13 pm
Hi,
Had the same problem on my twins. The choke cable would pull in and out no problem(inside the cabin). The car after numerous attempts to fire,would finally fire then run on two, then three and finally four cylinders as it warmed up. By chance I checked the choke and linkage whilst a friend engaged the choke cable from inside the cabin. Whilst the choke cable was working fine inside the car, under the bonnet- one choke was sliding up and down, the other side was stuck. After fixing the ceased side, the car starts with the choke on after 2 or 3 turns.
Thanks
PostPosted: Thu Aug 11, 2005 4:28 pm
Is the timing too far advanced? hence kicking back?
Pumping SU does nothing! :lol:
When mine was too advanced (only by a degree or two) it would be a bitch to start. Always kicked back after a few spins. When i retarded it, hey presto! started every time but it went like a pile of loose bolts... It didn't like it so retarded. So I used the Dr Mini trick to start the car, I installed an ignition kill switch. I am now at least 5-6 degrees more advanced and it runs great, much more power. This is how I start my car with a dellorto:
Pump pedal 6-8 times, pull choke, turn they key for 3-4 seconds, flip the switch and way we go. Starts first time everytime.
This might not be the answer for you but I thought I'd bring it up as it puzzled me for ages why my car was hard to start. It was all about timing. I am pretty sure JAM would run good if not better on more advance so maybe installing a kill switch could be the answer?
PostPosted: Thu Aug 11, 2005 4:32 pm
My 1100 with twin carbs starts first time everytime. Even when it is -7 it starts first time, that is what I want when it is my daily drive to work car.
Make sure the choke works.
It should not be hard to pull. (Tip, Push the accelerator down when you pull the choke out, it takes the load off the throttle cam on the choke)
If it is starting on one or two cylinders and then the others chime in later it sounds like a spark plug problem. :wink:
PostPosted: Thu Aug 11, 2005 7:51 pm
NAV-MAN
I never had any issues starting NAV. not even when it was -9 :shock: in Canberra, and yes NAV was out in it as I forgot to put him to bed. :oops:
Check the gap in the plugs/points and double check the timing.
Has the cam been played with i.e. advanced?
Also the tappet clearance has it been checked since firing him up?
Lastly what fuel you using? NAV is a bit harder to start on regular than premium or optimax
PostPosted: Thu Aug 11, 2005 8:08 pm
J_A_M wrote:
hmmm...Kev said Barney was doing the same with twins....is it just a twins thing??
(BTW....my sister in law is having twins :lol: babies that is)
Barney's main problem is the twin HS4 choke linkage doesn't seem to be allowing full choke.. :?
Make sure yours does, also that the fast idle screws do actually give you one when choke is on.
PostPosted: Thu Aug 11, 2005 8:52 pm
GT1310 wrote:
yep.. I had very much the same problem.. lol
I gave up trying with twins. going for the 1.75"
The only thing I found was to have the choke out. and tip a JUG FULL of hot water over the fuel bowls. started up every time in the cold. 8)
If i did not do that and only just got it started it would run like a dog for ages. cough and splutter out the carbs.. :evil:
I had trouble getting mine started today and i had read this post so after trying another few time i did the hot water trick and started right away.
Nice tip GT. :D
unit
Cooper S Mk 2
PostPosted: Thu Aug 11, 2005 11:57 pm
ok,,,seems to be a lack of choke problem,,,very common with choke cables being very old & dry inside,,,,a little lube on both the cable inner & the carb jets as well should have it all sweet agin
& on the pumping the throttle pedal thing, just for those who don`t know & for those who think they know--->
Pumping the throttle on a """NORMAL""" cars carby (not injection ones) will actually squirt some raw juice into the chambers,,,SU carbs don`t have a squirt mechanism, so in effect, what some people have said about pumping will do nothing is """SORT OF""" right,,,HOWEVER!!!!!!!!!!,,,when you`re trying to start a mini without choke, then absolutely no throttle at all for the first few attempts will help draw fuel up with very little air, therfore giving as rich a mixture as possible without choke,,,but after the first few kicks, then it is benificial to actually pump the pedal ever so slightly as it will "OPen/Shut/Open?shut/Open/Shut the butterfly, which in turn adds fuel, then a tiny bit of air, then fuel, then a tiny bit of air & as it starts to actually fire up, then you can actually keep pumping the throttle every so small amounts tho & it will help fire it to life because every time you back off, it will draw fuel in & effectively "Pump" the carb
if you don`t understand what i`m saying here or you disblelieve me, then try it, but hardly touch the throttle when you do it, just a slight touch then off, slight touch then off etc, don`t open up the carb much at all , if you understand?
anyways, just thought i`d add that little bit of usless trivia to all those interested,,,some """KNOW""" what they`re talking about with the theory, but others """KNOW""" what happens in Practice :-)
yeah, ok,,,i`m getting cheeky no,,,i`ll shut up & go to bed :-)
PostPosted: Thu Aug 11, 2005 11:59 pm
Thats one of the first things i was told by my mini mechanic i reckon...
"why the fiddle sticks are you pumping the accelerator?"
"i dunno... get the fuel in there, easier to start?"
"not on an SU carby you dickhead"
aww shucks :x :lol:
PostPosted: Fri Aug 12, 2005 6:58 am
I think mine was a combo of:
1. Mixture too LEAN
2. Not enough choke
Sorted it last night I believe :D
Thanks all for the feedback!
PostPosted: Fri Aug 12, 2005 8:08 am
Glad you didn't get rid of the twins.. I'm not liking all these negative feelings towards the twin su's everyone seems to have! Mine were fine, and are now even finer after I re-kitted them. They love me and I love them and we sing songs together.
PostPosted: Fri Aug 12, 2005 9:43 am
Yeah Matt, I found exactly that when I was running a tired & cranky 998 with no choke cable.
First try with no throttle. It may kick over. Then do some tiny pumps as it cranks. That usually worked. Never thought about why, even though I knew SUs don't have a "tromp it pump".
If it was really cranky, I used to have to get out, pop the bonnent and wedge a rock or stick in under the carby to hold the choke on. Lazy I know, should have just gotten a choke cable settup.
PostPosted: Fri Aug 12, 2005 10:03 am
glad you got it sorted twin SU's are blamed for a lot of problems that are really caused by bad setup and unfortunatley a lot of so called mechanics have no idea how an single Su works let alone multiple carb steup work, allways good to find someone that is BMC/Leyland trained as they are about the only mechanics who have been trained on SU carbs. As ythe doc said make sure your fast idle screw/cams are adjusted correctly and the choke is lowering the the jet fully and then its just a matter of pull choke and hit starter, you only have to touch the throttle if you setup is wrong, seems I need to explain to our friend from up north as he seems to neglect the fast idle setup ( I can be cheeky to ) :lol:
