It is currently Sun Aug 10, 2025 12:27 am
 Post subject: Tacho reading wrong?
PostPosted: Fri Aug 12, 2005 12:17 pm
When driving JAM, I seem to be changing gear at 5000rpm, according to my tacho. It doesn't sound like the motor is doing 5000 rpm....so can a tacho be reading out?
PostPosted: Fri Aug 12, 2005 12:20 pm
Well, if your tacho was set for a 6 or 8 cylinder (aftermaket one) car then it would read wrong, otherwise be thankful for a nice quiet engine.
It'll get louder with age.
Is it the stock tacho?
Is the beast registered yet?? :D
PostPosted: Fri Aug 12, 2005 12:25 pm
I wouldn't bet on its accuracy, it's a Smiths... :lol:
They all have pisspoor damping and jump around with the vibes of a Mini.
Clubby one should not be miles out though, if reading steady.
PostPosted: Fri Aug 12, 2005 12:29 pm
hmmmm.....its standard tacho and loom etc...only non standard is the dizzy and coil.
Maybe I am taking it to 5000 each gear.....it does it with ease! :lol:
PostPosted: Fri Aug 12, 2005 12:32 pm
With the work your 1098 has, 5000 is a breeze. Don't believe all the BS from people that say 1098s don't rev and can't be made to. :lol:
Vizard was wrong... ask GR. Or all the guys racing 1098 Sprites. :wink:
PostPosted: Fri Aug 12, 2005 1:06 pm
With the work your 1098 has, 5000 is a breeze. Don't believe all the BS from people that say 1098s don't rev and can't be made to.:
1098s do have the power, mine has great grunt for the little engine :D
Jet Red Mini K
PostPosted: Fri Aug 12, 2005 1:08 pm
My 1100 loved to rev out. Fairly stock apart from sprite head and exhaust.
Never struggled to get to 5000, but you sure knew about it from the noise.
 Post subject: Re: Tacho reading wrong?
PostPosted: Fri Aug 12, 2005 1:26 pm
Have you done a double check against the speedo?
You know your diff ratio xx = ??kph @ 5000rpm
It's probably OK, it's just running super sweet 8)
PostPosted: Fri Aug 12, 2005 1:40 pm
I need to take you for a run in Lillee anton... She goes ballistic from 2500 to 5500 in very short time indeed! :lol: I am sure jam rides the RE13 like an out of control freight train from 2500+... I'd be purprised if it didn't actually.
You can borrow my Fiat tacho if you want, it's very accurate 8)
PostPosted: Fri Aug 12, 2005 2:48 pm
I wish Sue would allow me to put a Tacho in Morris :cry:
PostPosted: Fri Aug 12, 2005 3:02 pm
Get a cheap digital one from an electronics shop, and mount it where it can't be seen except when its on.
