It is currently Sun Aug 10, 2025 2:36 am
PostPosted: Fri Aug 12, 2005 4:01 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
what about a big end ??
they make that sorta sound when a bigend lets go to
mkka
PostPosted: Fri Aug 12, 2005 4:02 pm
Hmmmm
either way it's another f**king rebuild :evil:
Anyone feeling generous with their time this evening??
Bob Slattery
PostPosted: Fri Aug 12, 2005 5:31 pm
big end was gonna be my guess. sorry Bob, moved into the new house yesterday so i gotta unpack boxes and get life back to normal ( i have not shaved for 3 weeks!), once that is done i can get to work in the garage whether it be mine or someone elses :D
PostPosted: Fri Aug 12, 2005 5:36 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i'd offer but i have a shed full to :(
makka
PostPosted: Fri Aug 12, 2005 7:13 pm
Bob,
After telling me how you `did it' today, my guess is a piston. Or just maybe, a bent rod... :wink:
PostPosted: Fri Aug 12, 2005 8:31 pm
Ouch, either way that's not good. I feel for ya Bobbeh! :(
If I were even in the southern hemisphere I'd offer to help...
Lillee - 1969 Morris Mini K
PostPosted: Fri Aug 12, 2005 8:36 pm
Having fun in Minnesota eh!
Y'all come back now, you hear... 8)
PostPosted: Fri Aug 12, 2005 8:51 pm
Bob,
Hmmm..just wondering...if the bore was OK and the Crank was OK...
could you...
Wip the head off...split the engine and box....and
pull the offending piston and rod...drop another piston and rod in....maybe new bearings on just the one....
would this work :?:
PostPosted: Fri Aug 12, 2005 8:57 pm
Depends what the bore and crank are like.
Can't tell until post mortem.
You would want to strip the motor anyhow. :wink:
PostPosted: Fri Aug 12, 2005 9:02 pm
I will regardless I have decided.
I am sick of band-aid solutions, I just want it right. I will strip the bastard and try and rebuild it as strong as possible, without parting with mega $$$$ I hope :shock:
Depending on what's wrong with it and How much time/money I can muster up I may do "a little" to it if I can - I'll just have to wait and see.
I don't think I'll start until Sunday or monday now. At least I have some time off work, and my best mate has lent me his motorbike so I'm semi-mobile until I fix it.
Any suggestions of HP or reliability gains for not too much money appreciated!!! I know not much happens with cars cheaply but I'll see how I go.
Bob Slattery
PostPosted: Fri Aug 12, 2005 9:41 pm
Well my best Bang for your buck would have to be the RE-13...absolutely transformed the car 8) ...i'd call it cheap too ;)
PostPosted: Fri Aug 12, 2005 9:42 pm
Was already thinking about that. How about if I need new rods, offset grinding the crank???
Bob Slattery
PostPosted: Fri Aug 12, 2005 9:46 pm
If you do that you will need to take ~1.5mm off the piston tops. Depends what ones you have in there... :wink:
PostPosted: Fri Aug 12, 2005 9:51 pm
ooops, sorry mate, I am late in on this one.
BUGGER!!
That's bad news mate. :( My sympathy goes out to you.
PostPosted: Fri Aug 12, 2005 9:54 pm
Fairly big dollars there. If it is a broken crank the fix is fairly painless as regards internal damage. The dollar damage is a bit painful though. Rather the crank than a rod or piston. To stroke it you need a big journal crank and correct rods.
Chris
Everything I like is either
Users browsing this forum: No registered users and 116 guests
