It is currently Sun Aug 10, 2025 12:30 am
PostPosted: Fri Aug 12, 2005 8:07 pm
hey guys, what way up do the brake callipers go on cooper s brakes? does the bleed nipple point up or down, or doesnt it matter?
i hope somone knows!
sean
Potato
PostPosted: Fri Aug 12, 2005 8:17 pm
sean
commonsense would say the bleed nipples go to the top!! :lol:
Pete
PostPosted: Fri Aug 12, 2005 8:22 pm
I'm not having a go at you Sean but you can't have built an entire car without a manual?
PostPosted: Fri Aug 12, 2005 8:23 pm
bleed nipples go at the top.
PostPosted: Fri Aug 12, 2005 8:25 pm
top cause the air rises :wink:
PostPosted: Fri Aug 12, 2005 8:26 pm
Nipples up top, air bubbles travel upwards so that's where you want to have your bleed nipple, otherwise air will always be trapped in the calliper
PostPosted: Fri Aug 12, 2005 9:01 pm
oh you can mount them the other way up tho(,nipples pointing down,)
Just that you`d have to take them off & hold them upside down to bleed them, them fit them back on for it all to work :-)
hee hee...i`m such the argumentative type :-)
see,,,if you were ever stuck with a broken caliper & you only had 2 left calipers or 2 right calipers, then you can still fit them up & they`ll work just fine, just that you`d have to bleed the odd one with the nipple pointing up , then fit it back on upside down
at least someone might benefit from that usless trivia :-)
I`m so full of it hey?
PostPosted: Fri Aug 12, 2005 9:05 pm
If upside down, just remember to put something between the pads when you bleed it off the car...
I know someone on this board who has 2 LH ones.. anybody got 2 RH ?? :lol: 8)
PostPosted: Fri Aug 12, 2005 9:19 pm
I`ll swap you a left for a right :-)
I mean, your left for my right
PostPosted: Fri Aug 12, 2005 9:23 pm
I'll pass the message on when I see him. He's `out of the country'... but on this site... 8)
PostPosted: Fri Aug 12, 2005 9:26 pm
Oky Doky Docy :-)
PostPosted: Fri Aug 12, 2005 9:28 pm
expect a PM.... :wink:
PostPosted: Fri Aug 12, 2005 9:30 pm
Watch out or i will expect that PM , ,,,Don`t just dare me to expect that PM,.,,cause i`ll take you up on that dare & actually "read" that PM & probly even reply to it :-)
PostPosted: Fri Aug 12, 2005 9:31 pm
Do tell.... :lol:
PostPosted: Fri Aug 12, 2005 9:34 pm
PM Sent already!!! 8)
