It is currently Sun Aug 10, 2025 12:38 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 12, 2005 9:11 pm
Anton I think it depends what needles etc you are using. With std roady lean ones you would get a flat spot.....
PostPosted: Fri Aug 12, 2005 9:28 pm
well,,,i dooooooo suspect that GR hasn`t fitted """STD""" #6 needles then :-) :-) :-)
PostPosted: Fri Aug 12, 2005 9:29 pm
I put them in, I inherited them a few weeks back. Look stock, no file marks... :lol: :lol:
PostPosted: Fri Aug 12, 2005 9:36 pm
yeah, well,,,i can give you a set of needles with a stamp on em & they`ll look factory till you measure em :-)
PostPosted: Fri Aug 12, 2005 9:43 pm
These are working OK so buggerit they can stay in there for now. 8)
PostPosted: Sat Aug 13, 2005 12:33 am
I think what Kev's saying...is the mixture F/A is now spot on with the thanks to GR. he is still using his #6 needles but with out Much oil inside the piston top.
I must say this 1293 is pulling nice and hard...when Kev turn up to my place after being around GR and took me for a ride...I was very surprised. Kev take the old owner for a ride with out the psiton dashpot dampeners in.. :shock:
Kev opened the bonnet..and I said your missing something...Kev had that smile...you want to go for a ride 8)
Interesting...2 stoke oil ay :idea:
PostPosted: Sat Aug 13, 2005 12:39 am
Huh I dun get it? :? Are you running oil or no oil in the dashpots??? Please explain! :lol:
Why can't you run ultra thin oil like sewing machine oil or whatever? SAE0-15 that sort of stuff?
Lillee - 1969 Morris Mini K
PostPosted: Sat Aug 13, 2005 12:47 am
Mate no oil....and no Caps :shock: what you screw into the dash pots 8)
PostPosted: Sat Aug 13, 2005 12:49 am
What?? no caps!? like as in no back thing at the top? so the piston is not in there???
Man that's Voodoo SU magic right there! :lol:
PostPosted: Sat Aug 13, 2005 6:57 am
OK- yes I took the dampers out and drove it home without.
Yes the dampers are in there now but without oil. I got home removed pistons and tipped it out. 8)
Yes I probably could run real light oil- but if no flat spots now when I nail it, why do it?
I'll try some 2stroke oil when the weather warms up... :wink:
PostPosted: Sat Aug 13, 2005 7:23 am
std #6 needles then the jets have done up in size?
I have heard of no oil but i suppose no dash pot plunger is the same as no oil as they dont work unless there is oil in them.
Quicker acceleration right no throttle lag etc.
PostPosted: Sat Aug 13, 2005 7:32 am
Jai I think the jets are standard, as it idles nice with the jets 10 flats down from level.
 Post subject: Eriks
PostPosted: Sat Aug 13, 2005 9:24 am
Care to tell us what the significance is of the new banner Doc....are you trying to be the Mini District Nurse.. :?: :D
rushing around to the rescue of broken Minis :shock:
 Post subject: Re: Eriks
PostPosted: Sat Aug 13, 2005 9:42 am
No Mick. Ask Chong- he's so bored in USA he did it for me!
I think key word is `sleeper...'
Users browsing this forum: Bing [Bot] and 87 guests
