Check that the external linkage that runs from the top of the diff housing to the input back into the gearbox are correct, and that the bolts in the clamps are tight, it sounds like you may have not quite got the alignment of these as they should be, have someone move the gearlever and check you may need to move it around on the spline a couple of teeth so it pulls a bit further. It is not the detents as they work on 1st-2nd plane and 3rd to 4th and the symptons you describe are just the external linkages
Jon
