It is currently Sat Aug 02, 2025 10:11 am
PostPosted: Mon Aug 15, 2005 9:16 pm
I'm with Harley
clutch plate sticking, burr on drive gear, incorrect combination of gear, flywheel, flywheel housing or burr on new clutch, does or did it slide onto gear easy or catch a little in pplaces.
steve
PostPosted: Tue Aug 16, 2005 10:51 am
clutch plate moved freely on the gear.
c clip was tight to fit on crank, now I think about it :?
They wear....so will this one wear, giving me the right end float?
I am Image
PostPosted: Tue Aug 16, 2005 10:58 am
J_A_M wrote:
I am Image
the brass monkey ball that froze off?
:lol:
PostPosted: Tue Aug 16, 2005 5:45 pm
I am Image
Given time maybe...
By the time it does your synchros will be stuffed.... :cry:
Take the flywheel off, measure end float (probably none), get the C-clip surface ground for .004" end float and it'll be sweet.
No need to pull ze motor.. :wink:
PostPosted: Tue Aug 16, 2005 6:31 pm
Did you put the front thrust washer on the right way around? i know if you put them on backwards they sit out because the inside edge is tapered... i made this mistake once and couldnt figure out why the c washer was much further out until i realised the thrust washer was sitting proud of the surface on the crank that it sits on. just an idea...
PostPosted: Tue Aug 16, 2005 7:15 pm
I was there when the clutch housing went on. I put the bronze thrust washer the right way round. The C-washer on crank was worn both sides & pretty loose (had around .015" end float) so I suggested to Anton he get a new one...
So he did. Maybe it's a little tight now.... :cry:
PostPosted: Tue Aug 16, 2005 10:42 pm
I loctited the flywheel bolt. Do I have to heat it up to crack it?
PostPosted: Tue Aug 16, 2005 10:56 pm
No, just need a s**t load of force.
PostPosted: Tue Aug 16, 2005 11:00 pm
Anton,
Put a bearing shell in the ring gear like I showed you, it's a safe way to lock it from turning...
Bolt will not be that tight to move. It's only 262 studlock... :wink:
PostPosted: Tue Aug 16, 2005 11:05 pm
ok cheers for the info. this aint gunna happen till AFTER the show and shine in Sept :wink:
Users browsing this forum: No registered users and 63 guests
