It is currently Sun Aug 10, 2025 10:45 pm
PostPosted: Wed Aug 17, 2005 5:51 pm
is it possible to fit one of these to the beast, if so how and where.
I have a problem.. apparently
PostPosted: Wed Aug 17, 2005 6:10 pm
:D
Its fitted into the oil gallery in place of the oil pressure light switch. If you wan't to keep the light as well as the gauge, which is a good idea, you need to use a T piece so you can connect the gauge and the oil pressure light switch. Not 100% sure but I think the thread in the block is 1/8" BSP parallel fastening thread so you need an adapter with this thread.
Regards
RonR
PostPosted: Wed Aug 17, 2005 6:11 pm
Simply unscrew the oil pressure switch & screw the fitting for the gauge tubing straight in.
Some universal gauges come with a couple of brass bushes to suit different sender/switch sizes in different cars.
Just make sure everything is nice & tight. Hot engine oil squirting out from under the dash is not nice :wink:
PostPosted: Wed Aug 17, 2005 6:18 pm
is the switch thing just up and to the left of the dizzy?
cos thats a pretty big hole....
PostPosted: Wed Aug 17, 2005 6:25 pm
the hole for the sender is no bigger than the hole for th water temp sender. in fact there the same diameter. I woud recomment putting a t or y peice in as if you don't your oil pressure warning light will never go off :cry:
Aaron
PostPosted: Wed Aug 17, 2005 7:02 pm
there was never anything connected to it...
PostPosted: Wed Aug 17, 2005 7:06 pm
I always keep the oil pressure light as well as having the gauge.
I fit a 25psi oil light switch so the light comes on before the bang not during the bang. :wink:
PostPosted: Wed Aug 17, 2005 7:55 pm
High heel ninja
Yellow engine YUK :oops:
Doogie
Just my opinion, i say go with Cooper S metallic green 8)
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 130 guests
