It is currently Sun Aug 10, 2025 10:41 pm
 Post subject: head torque setting?
PostPosted: Wed Aug 17, 2005 8:58 pm
So what should it be for an 1100s 1275?
I bet some of you know where this is going.....
Aaron
PostPosted: Wed Aug 17, 2005 9:09 pm
43 lb/ft according to the book. That's for an S, it's what I use.
Some Oz 1098s with bolts are supposed to have them at 50 lb/ft but these days the old bolts break.. I will never use another headbolt.. :evil:
PostPosted: Wed Aug 17, 2005 9:13 pm
Interesting as i have a dozen manuals and some say 42, 54, 65.......
42 is what i did and it leaked still. Graham russell gave it a skim and the head is now flat but i still have the same issue with 42ft/lbs....
So i tightened to 54ft/lbs and it seems not to leak....
I am so confused! :cry:
Aaron
PostPosted: Wed Aug 17, 2005 9:16 pm
Check your torque wrench calibration.. some are miles out! :lol:
yeah you are right it's 42, not 43.. dunno where you got the others though!
Last edited by drmini in aust on Wed Aug 17, 2005 9:18 pm, edited 1 time in total.
PostPosted: Wed Aug 17, 2005 9:17 pm
How do i do that?
Aaron
PostPosted: Wed Aug 17, 2005 9:21 pm
I have an old dial one here I use to check my Kinchrome `clicky' one against.
As it's just a simple beam in bending, I think it's fairly predictable. Bring yours over sometime and I'll compare it. :wink:
thanks for the reminder Aaron....I need to retorque mine.
What happens if you over tighten head bolts? What's right for a 998 / 1098?
Good to see you are sorted now Aaron.
PostPosted: Wed Aug 17, 2005 9:24 pm
The book says 40 lb/ft if you have nuts & studs.. like yours. :wink:
I loosen each one 1/8 turn then tighten, move to next one and repeat. Follow tightening sequence in book. Middle one outwards.
Good idea to recheck rocker clearances afterwards.
Users browsing this forum: No registered users and 121 guests
