It is currently Mon Jul 28, 2025 4:23 am
 Post subject: Wheels
PostPosted: Wed Aug 17, 2005 11:11 pm
I need some help with wheels.
I'm looking for a bargain, so have been looking around at other brands of wheels which could be redrilled to suit a mini.
I haven't been doing so well thus far :cry: :oops:
So far I have bought a set of 12" Datto Wheels, and a set of 13" Hotwires (Suit Corolla).
Neither can be re-drilled because the Stud pattern is WAY too different to Mini.
Now I know that Mini's have 4 inch PCD (or at least I think that's right??)
Can anyone think of any cars with a similar PCD - Not talking the same, but similar?
Escort maybe??
Also, what is PCD?? I know you measure centre to centre, but is it from the stud holes next to each other or diagonally?? And is the 4 inch measurement for Mini's right?? And what is the size of the bearing cap hole in the centre??
H E L P ! ? !??! :oops:
Bob Slattery
PostPosted: Thu Aug 18, 2005 8:01 am
You measure from stud to the one next to it NOT diagonally.
The first of the Holden Toranas (HB I think they were called) had the same stud pattern if that is of any help.
Pete
PostPosted: Thu Aug 18, 2005 8:50 am
Yeah I thought I was measuring it correctly.
HB's aren't all that common - same problem with finding mini wheels.
What I was looking for is just something close to mini so they can be re-drilled easily.
Does anyone know of an online listing of PCD sizes??
Bob Slattery
PostPosted: Thu Aug 18, 2005 9:01 am
Slow-Po
I couldn't find anything on-line that has a vehicle like for like type listing. I would suggest that you call a couple of the large tyre places asking for 2nd hand mags for a Mini, and while you're talking to them ask them what other vehicles wheels share the same PCD. The should either have a cattle dog to reference or know the lists off by heart.
PostPosted: Thu Aug 18, 2005 10:30 am
not a bad idea that speedy. When I finally get this crank sorted out I'll do that.
Bob Slattery
PostPosted: Thu Aug 18, 2005 10:41 am
A PCD (Pitch circle diameter) is measured diagonally on a 4 stud wheel.
PostPosted: Thu Aug 18, 2005 1:42 pm
A picture being worth a thousand words & all that...
PostPosted: Thu Aug 18, 2005 2:51 pm
Correct me if I am wrong, but I am of the understanding that it is illegal to re-drill wheels.
Get a set of ROH Contessas for around $250.
Morphias. :)
_______________________________________________
If you're not living on the edge, you're taking up too much space...
Users browsing this forum: Bing [Bot] and 77 guests
