It is currently Fri Jul 18, 2025 10:56 pm
PostPosted: Mon Aug 02, 2004 9:27 am
is there an easy way to tie down the wheel in the boot? have they ever been tied down in minis? maybe a long bolt through the centre with a circular piece of steel on top of the wheel?
PostPosted: Mon Aug 02, 2004 1:32 pm
yep thats been done... factory in some minis even
its a nut and stud that are welded to the bottom of the boot floor
and you do up a nut on the top to hold down
im not sure which hole, maybe the centre maybe one of the little stud holes
if you want the real deal ill have a look this arvo in my "restoring the mini cooper" book
Inconspicuously Conspicuous
PostPosted: Mon Aug 02, 2004 2:14 pm
Pfft, four words for you my friend, "two inch duct tape" :wink:
PostPosted: Mon Aug 02, 2004 7:57 pm
Early cars had a captive nut in a raised bump in the wheel well. There was a big tee bolt supplied to clamp the wheel down.
Discontinued in the late? 60s, not sure what year.
PostPosted: Mon Aug 02, 2004 8:39 pm
Not fitted to my '68 ......
I just got a heavy-ass Contessa and a "Snow Tyre" ..... doesnt move a bit....
J
PS - reminds me, must swap contessa for "S" Offset contessa as spare.... would handle a bit weird with an extra 1" offset on a spare tyre...... :shock:
PostPosted: Mon Aug 02, 2004 9:25 pm
Keep an eye on them S offset ones, they crack... ask 68delux... :cry:
PostPosted: Tue Aug 03, 2004 1:21 am
You could always go to the local hardware store, buy a LONG bolt, 3 mudguard washers, a nut and a wingnut to suit....
Mount the bolt from under the boot floor so that it pokes up thru a nut hole on your spare rim. Lock the bolt to the floor with a washer both sides of the floor, the nut inside the boot. The rim then gets held down by the washer and wingnut...
Worked for me when i had a defect removed a couple years back.... (was the only time i carried a spare, cos i HAD to)
This same thing could work for the battery too, with a few mods...
PostPosted: Tue Aug 03, 2004 7:06 am
As Minis from 1966? on had nothing to hold the spare down, why bother? It can't go anywhere... no room! :lol:
PostPosted: Tue Aug 03, 2004 9:26 am
Thanks for all that. I know its not going anywhere but cause my ride is pretty stiff and the roads here are crap it bounces around a bit.
Cheers!
PostPosted: Wed Aug 04, 2004 1:40 am
I wonder if you can get "space saver" spares to suit a mini?? Not that i want one, they'd just be funny to see....
PostPosted: Wed Aug 04, 2004 4:28 pm
The new Honda Jazz comes out with a space saver wheel....almost the same stud pattern...........come to think of it, it might be wider than a standard mini :roll:
I have got an old 10" kids pushbike....interested???
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Wed Aug 04, 2004 8:03 pm
I believe the Minis had space saver wheels all round! 3.5" rims, the original ones should really have had a 80km limit sticker on them like the modern space savers :)
PostPosted: Wed Aug 04, 2004 8:38 pm
Heh- we used to do 100MPH on those! 5.20x10 cross plies, too... :twisted:
