It is currently Fri Jul 18, 2025 1:24 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Aug 25, 2005 1:32 pm
G'Day,
From what I could see from the picture (my poor eyesight), while the Lucas 23D4 distributor does not need vacuum advance has the carby vacuum advance takeoff been blocked off?
Over 1,000,000Km, but now my retirement restoration project
>>what do you mean by "adjusted the dizzy from scratch" ?
We set the car to 10 degrees off of TDC and then we got the screw-driver with the light and attached it to the block and to the dizzy and rotated the dizzy until the light comes on. Then we rotated the dizzy so the light just turns off. (If that all makes sense)
We have not used the timing light as the car doesnt idle nicely so I thougt that perhaps this wasnt a good time to do the timing?? I thought it may have been due to a air leakage or something and went on to fix that.
>>You have the leads connected up the right way firing order 1-3-4-2 ?
Yep.
>>I can't remember which way the dizzy turns anyone? think it's anti clockwise
Im doing them anti-clockwise.
>>will have to look in the book at home for the float level in the fuel bowl
Okay thanks
>>I think the standard setting is 2 1/2 flats.. so you are way out there.
Ohh.. I have been told many different numbers from many people. As I am running the H6 needle I was told the motor needs to run rich so...
I did try and run the car on 0 and 2 and 4 but it wouldnt keep going unless the choke was out.
PostPosted: Thu Aug 25, 2005 1:42 pm
Yeah... it has a cap over it... its like a plastic bit which goes on the end.
I'll upload a closeup of the carby when I get home.
The other thing I'd like to add is that when I say the engine slows down and then revs up when it revs up it ROARS... then it struggles.. then it ROARS.. then it struggles.
PostPosted: Thu Aug 25, 2005 1:48 pm
anyone else see something about the carb that is different? :lol:
PostPosted: Thu Aug 25, 2005 1:59 pm
No suction port for PCV??
Probably off a Morris 1100S, or 1300 auto then. :wink:
PostPosted: Thu Aug 25, 2005 2:06 pm
is it not a right hand carb 2? mine the fuel bowl are on the other side.... :?
and is there ment to be a little plate clip on the fuel bowl on the top inlet area to cover that little hole?
PostPosted: Thu Aug 25, 2005 2:32 pm
All the single HS4s had a RH bowl like this one.
PostPosted: Thu Aug 25, 2005 3:05 pm
well there you go. learn something new every day 8)
I only got HS2s and HS6 laying around..
PS: HS6 is all clean and rebuilt waiting on the GR manifold that Chris is droping of to me on the weekend. the clubby go fast. :shock: :P
PostPosted: Thu Aug 25, 2005 3:11 pm
Yeah that thing you're talking about exists.. its on the other side and cant be seen in the photo.
PostPosted: Thu Aug 25, 2005 5:53 pm
Electric or mechanical fuel pump? Is there enough petrol getting into the carby? The old Victa (really old) lawn mower could only be turned off at the carby and you had to wait for it to drain the carby fuel bowl. Near the end it always revved right up just before sputtering out. Sounds like its getting real lean, such as fuel bowl emptying. Check lines, filter and fuel pump. May even be crap in the lines from the fuel tank or in the pickup inside the fuel tank. (Is it new fuel?)
Question on the Photo
I can see the Choke Cable where is the Go Fast cable
PostPosted: Thu Aug 25, 2005 6:01 pm
yeh i noticed that too.. wheres the acceleration cable?
PostPosted: Thu Aug 25, 2005 6:44 pm
Heh - its not attached as he end was requiring some solder and I havent been home to do it. It is around.. just not connected =)
PostPosted: Thu Aug 25, 2005 7:15 pm
Is the exhaust blocked? If it had a vacuum leak I would suspect you may be able to hear it. Pour a bottle of water over the manifold and all vacuum connections and lines when it is going. Any speed change will become apparent if there is a leak. Can't see it being much else. Fuel supply at idle will only do one thing, flood or not run, timing won't do it, wrong firing order ditto. Is it running on all four, I suspect it is.
Chris
Everything I like is either
PostPosted: Thu Aug 25, 2005 7:25 pm
I havent checked the exhaust pipe itself.. I know that a lot of smoke pours out of it =)
I know that the top of the exhaust pipe that connects to the manifold has a crack in it.
(Planning to replace the manifold and exhaust with extractors when this bit works)
How could I test this ? disconnect the exhaust from the manifold for a minute ?
