It is currently Tue Jul 22, 2025 2:15 pm
 Post subject: 99.9% Running Great
PostPosted: Sat Aug 27, 2005 10:04 am
Here's the thing folks - had to get another head for Ribena - all done and all that sort of thing - the little beast will scoot along at about 130 kph with very little hassle. Not bad for a 998 with extractors imho :D
Anyway, curiosity has the better of me coz there's always room for improvment - no matter what you do - how do I tell if it's running too lean or too rich??? And to fix it, I adjust the main jet underneath my single stock standard carby - screw it in by one flat at a time to make it less rich. Is this correct????
P.S. Do you like the new wheel trims - have a look in the photobucket under "Wheel Trims" - hmmm.......Obvious name for it Rod
Rod Image
 Post subject: Get some advice ..quick!
PostPosted: Sat Aug 27, 2005 12:10 pm
In the interests of not cooking your new head, I recommend you get the Mini to someone who knows SUs ASAP....
Or someone with a sensor to poke up its little exhaust...or the Docs air/fuel meter!!
if you don't know what youre doing...you could lean it out and risk damaging an expensive hunk of iron :shock: :lol:
PostPosted: Sat Aug 27, 2005 7:02 pm
If it's not running too hot, then it's not running too lean.
Pete has one of those things ya stick up ya exhaust. Lyndsey was in there adjusting his a coupla weeks ago.
PS - wheel trims looking great!
PostPosted: Sat Aug 27, 2005 8:20 pm
Just as soon as Pete is sorted out, think I'll get his "sniffer" sniffing :lol:
Rod Image
PostPosted: Sun Aug 28, 2005 12:01 am
NAV-MAN
I wouldn't rely on the engine getting hot to tell you it's too lean.
Trust me, NAV was running in the 16/17 bracket for air fuel ratio, he wasn't getting hot at all. Tis all good now he has a custom needle formerly an ABX but now it's A?? but he goes good now thanks to roy goodman
PostPosted: Sun Aug 28, 2005 1:42 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
roy goodman hmmmmmmmm
i think he used to have a shop in here insydney he built my mates lotus twincam in his escort and if it is the same goodman i used to knock his daughter off lol
makka
PostPosted: Sun Aug 28, 2005 10:26 am
NAV-MAN
makka
I don't know makka if it is. His wife is Joy if that helps you at all
He's based in Woolgoolga
