It is currently Thu Aug 14, 2025 5:29 pm
 Post subject: Upper ball joint boot
PostPosted: Sun Aug 28, 2005 5:25 pm
Does any one know if the upper ball joint boots for a mini will fit a metro?
The upper boot on my metro disc brake conversion is split
Cheerd chasg
PostPosted: Sun Aug 28, 2005 6:29 pm
Cheerd chasg
You wouldn't believe I just threw four second hand ones out would you? I suspect the metro ones are MUCH bigger than the mini one.
PostPosted: Mon Aug 29, 2005 7:08 am
These are really cheap from any place that stocks ball joints or mini parts... Like under $1
Lillee - 1969 Morris Mini K
PostPosted: Mon Aug 29, 2005 8:39 am
Chong these are Metro ones, different to a Mini, I think.. :? Never ever seen one, round these here parts... :wink:
PostPosted: Tue Aug 30, 2005 8:20 pm
Apparently you can use tie rod end replacement boots from repco.
They come in 3 sizes. The part nos are TE1, TE2 and TE3.
The one to fit the metro is either a TE2 or TE3. l will buy one of each and try them.
Cheers chasg
PostPosted: Sun Sep 04, 2005 6:23 pm
Replaced both upper ball joint boots today. The passenger side boot also had a slight tear. The replacement boots for the metro are the repco TE 3. Cost $6.00 for the pair
PostPosted: Sun Sep 04, 2005 8:41 pm
And are they much bigger than the mini one?
