It is currently Thu Jul 31, 2025 7:18 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: My Blocks
PostPosted: Mon Aug 29, 2005 8:37 am
Over the weekend I desided to pull two blocks apart
Here is my 1275 Cooper S and 998/1098 Cranked Blocks
both look in great condition...with the bores look nice and smooth..so I think I al luck...the 1275 is + .40 and the 998/1098 is fresh as
As you can see thier are many layers of paint on the 1275 s theyboth will get a good clean up...Should I acid dip them or what
Both cranks seem to have a nice ring to them also...so I will be pleased but I may get them double checked before going back in
that also goes for these little babies :wink:
It looks like all bearing need replacing but I would say I was going to do that anyway...just to be safe
The 1275 will be put back together again but the 998/1098 may have something else doneto it..but thats a secret for the moment :shock:
PostPosted: Mon Aug 29, 2005 8:42 am
I'll come & bring micrometer this morning, will check the cranks for wear. 8)
PostPosted: Mon Aug 29, 2005 8:44 am
:wink: Excellent..the cam is a Cooper S one also Nice wide loabs
PostPosted: Mon Aug 29, 2005 8:57 am
:shock: MY GOD. JIM DID MINI WORK ON A WEEKEND.... :shock: :shock: :shock: :shock:
Whats the world comming to? :P
PostPosted: Mon Aug 29, 2005 9:24 am
Can see the tip your work boot poking into one of those photos there gaf :D
PostPosted: Mon Aug 29, 2005 9:27 am
Yep it does look like my saftey shoe's were on again :lol:
I think they need some blinging also...
PostPosted: Mon Aug 29, 2005 9:37 am
whats the part number for a 1275 crank?
PostPosted: Mon Aug 29, 2005 9:50 am
hahaha it wouldn't be authentic Jim mini pictures without a toe showing in the picture! Classic! :lol:
PostPosted: Mon Aug 29, 2005 10:00 am
I wouldn't acid dip the blocks until ya go to rebuilt the engine. Stop it going rusty.
PostPosted: Mon Aug 29, 2005 11:13 am
Anton AEG479/480 EN40B cross drilled, nitrided, 1.625"
Well they have been inspected by the good Dr
The Cooper S Crank as above just needs a polish on the mains only...who ever installed it last time did not put ACL Bearings into..so just a little polish is required. the 1098..is perfect....they both has a very nice ring to them..."ting" so no cracks
The 1275 Block need a light Honing and that all..998 block I'll take up to its first step +.20..So all are good
Cam is a 1100s so that will get a RE13 grind and so will the standard 998
So as its stands I am very lucky
So it will be wire wheel time for both blocks and pass them both on to GR to work his magic..with a little something extra for the 998 block :shock:
:wink: am I happy you betya
PostPosted: Mon Aug 29, 2005 11:51 am
AEG479/480 common Mk1 & 2 1275S crank, EN40B material, X-drilled & nitrided
12G1505 big journal 1275 crank (common one here in Oz) EN16 this one can be stroked or destroked if you find a good one...
CAM6232 big journal rolled fillet radius, A+ motors. Not good for stroking.. EN16
12G1287/8 for small journal 1275 crank EN16.
AEG623 small journal for 1275S, tufftrided EN16- supposedly used in last of Mk2 S. I've never seen one... :roll:
:wink:
Last edited by drmini in aust on Mon Aug 29, 2005 12:24 pm, edited 1 time in total.
PostPosted: Mon Aug 29, 2005 12:19 pm
Nice one on the motors Jimbo..... 8)
Kev...so many cranks :shock:
Do cross drilled cranks have a double hole on the journals? Like 2 holes in 1?
I think I have one of them .... :?
PostPosted: Mon Aug 29, 2005 12:25 pm
Crossdrilled S cranks have 2 holes in the big ends, but the outer hole should have a brass plug in. If it hasn't fallen out... :lol:
PostPosted: Mon Aug 29, 2005 12:37 pm
yes mate, you should POLISH those blocks! :lol: :lol:
Users browsing this forum: Bing [Bot] and 89 guests
