It is currently Sun Jul 27, 2025 8:40 pm
 Post subject: Rusty fuel tank repair?
PostPosted: Sun Aug 28, 2005 8:55 pm
Is it possible to braze holes in a fuel tank?
Got a RH tank with a hole in it.....can't throw it out - need to repair it.
PostPosted: Sun Aug 28, 2005 9:03 pm
Take it to a radiator place. One in Castle Hill did Barney's. They brazed it or leaded it, then put a resin kit (from bike shop) in it.
:idea: PM Baracade he just got his 2 done. :wink:
PostPosted: Sun Aug 28, 2005 9:17 pm
Yea that was my thought. No different to a radiator.
Thanx. I'll sus it out.
PostPosted: Sun Aug 28, 2005 10:05 pm
I cleaned one up and externally fibreglassed it, lasted for years. Lead wiping would work, but fibreglass is easier and definitly non flammable. I saw some CIG guys at Amaroo Park take a damaged tank out of a car, empty and rinse it. Then they purged it with CO2 and welded the hole. I left the pits before the welding started, I just wasn't that brave.
Chris
Everything I like is either
PostPosted: Sun Aug 28, 2005 10:43 pm
Except for the fact you have a volatile mixture inside. Don't blow yourself up Anton! :oops:
PostPosted: Sun Aug 28, 2005 11:36 pm
Superior Radiator just did me a good deal down in moorebank
Baracade
 Post subject: and the cost was??
PostPosted: Mon Aug 29, 2005 8:06 pm
What sort of dinero are rad places charging for this type of work :?:
I have a large tank with pinholes.....
supplementary question: if you filled a fuel tank with sand would that make it safer to weld :?:
PostPosted: Mon Aug 29, 2005 8:39 pm
If your tank has a rust hole it will probably get more rust holes so you need to fix the rust. Por 15 make a fuel tank repair kit. You just tip the stuff into the tank and slosh it around and it coat the inside of the tank. Problem fixed for good.
There are other brands around.
PostPosted: Mon Aug 29, 2005 9:06 pm
Good idea to put some gravel in there first and rumble it around, gets rid of the loose stuff.
I'd be game to weld or braze it, but only if it was hotwashed, upturned and 98% filled with water while I did it... :wink:
Then put a POR15 kit in it.
PostPosted: Mon Aug 29, 2005 9:17 pm
I had a diesel tank welded, he did it full! 8)
I had a petrol tank welded at Winton, we flushed it with water 3 times and filled it with exhaust fumes, the bloke lit the oxy and stuck the torch straight into the filler pipe :shock: Guess he figured if it was going to blow he would at least know when it was going to blow!
PostPosted: Tue Aug 30, 2005 11:09 am
You could also fill it with dry Ice so that there wouldn't be any chance of combustion.
Daily Driver - Yellow Devil 76 Clubman
Restoration Project - Primer grey 66 Morris Mini Deluxe
PostPosted: Tue Aug 30, 2005 11:37 am
Good idea. You wouldn't need to fill it- a few handfuls would do- dry ice boils off free CO2 gas... 8)
PostPosted: Tue Aug 30, 2005 11:40 am
Wash twice with hot soapy water (degreaser)
Leave out in the sun venting for a "couple a days"
Wash again with hot soapy water
Safe as houses.
Diesel on the other hand keeps leaching out after 5 or 6 washes :roll:
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62, Steam and 84 guests
