It is currently Fri Aug 01, 2025 1:28 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 29, 2005 9:45 pm
Thanx Dr Mini & Kazjim
Ill have to come borrow ure ball joint splitter again james once I get all the gear together.
Looking forward to have a safe front end :)
No more Minis!......For now.
PostPosted: Mon Aug 29, 2005 9:57 pm
Anytime Max....
Come over some time next week (wednesday ?) take the Brick for a spin.. she should be nice(r) by then !
J
PostPosted: Mon Aug 29, 2005 10:04 pm
The Brick! The Brick!!
Sooooooooooo cant wait to see it going again!! :D
PostPosted: Mon Aug 29, 2005 10:07 pm
Its going...... :twisted:
Need to sort out the boost issue (no more then 5Psi at the moment)
need to sort out an intermittant miss over 6000RPM ... I'm thinking spark again.... it seems to break down at higher revs... I'll close the gaps a little and see if that sorts it.. otherwise, I'll drop in a little more fuel.....
J
PostPosted: Mon Aug 29, 2005 10:10 pm
I swapped that 1.75" carbie I had, im going to be sensible and put on a 1.5" carbie (came with airfilter + manifold...and doesnt need kitting)
I REALLY hope it arrives 2moro, that way I can wack it on and tune it all tuesday before I have to go back to work on wednesday
