It is currently Sat Jun 28, 2025 4:48 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Sep 01, 2005 9:55 am
Well guys, finally finished the exhaust which I thought would never be finished. So on Tuesday it went out to M&A engineering to get the driveshafts made up. No word yet so probably next week. Also got the loom out of the car last night so things are starting to move again...
Dumpipe...
Out of turbo...
Undercar
PostPosted: Thu Sep 01, 2005 10:38 am
Geesus! So much power she's glowing red hot! :P
Looking good there 8)
PostPosted: Thu Sep 01, 2005 11:47 am
is that vdh paint? hi temp stuff.
I hope you have better success then I did.
After about 3 months it flaked off my extractors.
PostPosted: Thu Sep 01, 2005 1:52 pm
Mano, yeah the 1200F stuff. It was mainly to stop it rusting. I left the dumpipe sitting on the bench for a week and it started getting a oxide sheen...Oh well good enough for the mo...
PostPosted: Thu Sep 01, 2005 2:21 pm
did you pinch the pipe to suit the flanges?
PostPosted: Thu Sep 01, 2005 2:36 pm
Not sure what you mean by pinch. The flanges I got from my local exhaust place fitted snuggly over the OD of the 2.5" pipe so basically butt welded them in place. Does the job...
PostPosted: Thu Sep 01, 2005 2:59 pm
sort of bell mouth to suit the flange.
It just looked like you needed to go from round to rectangleish...
PostPosted: Thu Sep 01, 2005 3:29 pm
Nah Mano, ended up doing a cut to try and get a better angle to the other flange and ended up not needing ( :x ) it. That kind of makes the pipe look a bit funny but she's perfectly round all the way... :wink:
PostPosted: Thu Sep 01, 2005 3:35 pm
Looking good
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Thu Sep 01, 2005 5:55 pm
When you look up DIY on www.dictionary.com they now have a link to your website :D
bet you cant wait to fire it up and see what it sounds like matt? What did you do in the way of mufflers??
1974 Moke - 998cc
 Post subject: blackening the zorst
PostPosted: Fri Sep 02, 2005 7:05 am
Cheap way to save your dump pipe from oxidising:
clean back to bare metal
brush on gp grease
take out for a really heavy drive.
Burns the grease into a hard black layer that slows rusting
similar to a BBQ hotplate
PostPosted: Fri Sep 02, 2005 9:14 am
Besser I will take that on board, and if I am by the side of the road and want a steak I'll be away. As for the muffler I went a Lukey Straight thru twin exit. This thing really is straight through, hopefully it is quiet enough because I no longer have the cat... 8). But you're right Brad mate hopefully it will sound great...Also got the loom out of the halfcut last night, it looks like black spaghetti...Also does anyone know what these are?
PostPosted: Fri Sep 02, 2005 11:41 am
Not fully sure but looks like some sort of fuel cut defender knocks out the speed limiter and over boost if they are wired into the ecu loom.
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Sep 02, 2005 12:01 pm
That's what I was thinking. Def look aftermarket. Trace where they are connected to. Not exactly sure how the FCD's work but they are wired to the ECU. If they are FCD's and over boost cut put em in your thing. If you aren't running an aftermarket ECU that is.
Might be an idea to post on http://www.australetclub.com.au and see if anyone over there knows what they are..
PostPosted: Fri Sep 02, 2005 12:24 pm
Yeah well done guys that's what I thought. I'll trace them back and see if they lead to the ECU. At this stage will run standard ECU, budget doesn't go that far. Yeah Bungholio I will run it on Austarlet and see if I can get more info.
