It is currently Sat Jul 26, 2025 11:52 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Turbo mini people ?? Q&A
PostPosted: Tue Sep 06, 2005 12:32 pm
ok. for those that Run or have run Turbo minis. (not conversions...
what setups have you had? engine bay pics would be nice.. :lol:
I am just looking at the best way for me to setup the car. (evil850)
My main thing is atm is if I should mod the bulk head to fit the turbo at the back of the motor.
Now is the time to make the move before i prime and paint the engine bay.
I think this may be the best option as I will have a brake booster and intercooler in there 2, 8)
Thanks in advance
Cody
PostPosted: Tue Sep 06, 2005 1:14 pm
Also looking to do a turbo setup, got new pistons coming for the 850 guinny pig :twisted:
Umm, I'd say turbo box, becuase if you are fitting a intercooler and brake booster, these will seriously limit your engine bay space. I take it the brake booster will be standard fitment? ie. Right next to master cylinder area??
PostPosted: Tue Sep 06, 2005 1:39 pm
Move the brake booster under the dash. Mount the turbo over the gearbox. It can then draw fresh air from behind the grill. Mount the interwarmer in the drivers side wheel arch. Note - you will also need to make a provision for an oil cooler. Absolute must in my opinion if you are turbo'ing it.
PostPosted: Tue Sep 06, 2005 1:51 pm
o and remember I have no inner gaurds.. FLIP FRONT// so a few things can go out the side over the wheel. ie. washer bottle.
I think I will run the turbo down the back with the mod fire wall. almost time for the Avonbar racing order. :lol:
PostPosted: Tue Sep 06, 2005 1:58 pm
Modding the firewall may mean more efforts are required if it is to be engineered, aren't firewall mods supposed to be engineered?
Roads need more corners
PostPosted: Tue Sep 06, 2005 2:00 pm
yep. but I have to get the flip front engineered any way so one mory thing will not kill me. lol
PostPosted: Tue Sep 06, 2005 3:33 pm
I'd say defintely go the turbo box. Even if you move the turbo over the clutch housing (that's where I want mine) you've got extra room in the 'bay to run bigger/more/easier pipework.
PostPosted: Tue Sep 06, 2005 3:39 pm
I think thats the way I will go. + its easy to just buy all the after market gear from Avonbar racing.. :lol: less stuffing arounf making stuff.
PostPosted: Tue Sep 06, 2005 4:33 pm
iv started a turbo manifold for mine its made form 5mm thick mild steel and will house a t2 behind the engine with no firewall mods. only thing that has to be modded is the wastegate auctuater bracket as this will foul the firewall
PostPosted: Tue Sep 06, 2005 4:39 pm
Cool, any pics benjamin?
http://www.turbominis.co.uk/
Just found this site, on first looks it look pretty cool.
PostPosted: Tue Sep 06, 2005 4:40 pm
cool. but i think you may find with out the buld head box you may get to much heat transfer to the fire wall ... i have read of peoples carpet going up in smoke.. :lol:
and I take note of your sig pic.. HIF44 turbo carb?? I thought the HIF6 were the turbo carbs..?? :?
PostPosted: Tue Sep 06, 2005 4:43 pm
yep. its a good site takes a little bit to suss your way around. not as user friendly as ausmini 8)
PostPosted: Tue Sep 06, 2005 5:14 pm
no pics yet there will be a heat shield on the firewall and im not sure bout the naming of the carbie
PostPosted: Tue Sep 06, 2005 5:20 pm
hmmm interesting.... lol
this is the style of setup I will run.. :lol:
PostPosted: Tue Sep 06, 2005 5:46 pm
8) Minimal lag with it so close to the ports
That avonbar firewall box will replace your heater - in more ways than one :)
