It is currently Sat Jul 26, 2025 10:50 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Sep 07, 2005 6:09 pm
Some reading for you all interested in Turbos
http://www.grapeaperacing.com/GrapeApeR ... argers.pdf
:wink:
PostPosted: Wed Sep 07, 2005 6:22 pm
holy crap how nice is this :shock:
PostPosted: Wed Sep 07, 2005 6:27 pm
Nice and clean.. simple but good. :lol:
PostPosted: Wed Sep 07, 2005 6:37 pm
NOYCE :lol:
PostPosted: Wed Sep 07, 2005 7:10 pm
NOW THAT IS TIDY 8)
PostPosted: Thu Sep 08, 2005 12:31 pm
Lots of sweet setups. You'll be doing well Cody if yours ends out looking like those 8)
GT1310 wrote:
I think this may be the best option as I will have a brake booster and intercooler in there 2,
If you are having a brake booster, have you given thought to where you are going to get vacuum from? I don't think kazjim has this luxury. You may need to run a small vacuum pump & receiver. Boot mounted perhaps?
Mounting the brake booster under the dash is a PITA but will save heaps of room in the engine bay, and look schmick! Another possibility (haven't heard of anyone doing it yet) is to use the electronic brake boost as fitted to some modern cars :idea:
Just some thoughts...
PostPosted: Thu Sep 08, 2005 12:54 pm
O it will look like one of them. i dont care how long and how much $$ i have to spend...
There are still lots of things I need to read up on to work out how to set things up..
one thing I am not sure of is the fuel lines. running a carby setup do you need a return line from a fuel reg to the tank?
PostPosted: Thu Sep 08, 2005 1:05 pm
yes, but if you mount the regulator in the boot, then you will only need a shot section of hose (braided in your case :roll: ).
You will be using an electric fuel pump? Then incorporate the pump & regulator together in the boot & save yourself some trouble.
PostPosted: Thu Sep 08, 2005 1:10 pm
yes electric fuel pump.
I need a new tank. so I am going to get a MPI tank cause its got the other line on it already.
And the place where the mech. fuel pump was will be the oil return from the turbo. easy place to do it. :wink:
PostPosted: Thu Sep 08, 2005 2:35 pm
each setup has pro's and con's. I went the std metro conversion cause i did it in 96 when i did not know that much about turbos and i thought it was all easy mods (which it was) 8)
engineering the firewall was a piece of piss one visit by the engineer before and one after the box was welded in place but no painting and the other was for me to take him for a spin cause he loved it.
:D
i used std "S" brake set up wit booster and all was good.
i have had a few teething problems over the years but all and all i would not go back to n/a for what i want this car to be
GT1310 you are only at richmond, I am at kellyvile let me know if you want to look at it, but no can drive at the moment as gearbox is not happy :(
and i can still fit the MKI "S" heater in too :lol:
here are some pics
100% Pure A Series Turbo
PostPosted: Thu Sep 08, 2005 4:29 pm
Thanks mate...no real rush ATM evil can take as long as needed to be done the way I want. :lol:
I think its all starting to fall into place in my head of what i need and what to do..
over the next 4 weeks I hope to finish the painting under the car and around the car. get the subs built and in with the bulk head mod done..
once thats all done. I wall start getting the motor sent out for work. got a 1275 block, s rods, EN40B crank coming soon. just not sure how far out to work the block :)
What size turbo you running?
I got the new set of 7.5" disks waiting at home to.. :wink: just need the booster.
Cody
PostPosted: Thu Sep 08, 2005 4:33 pm
Great Pics, Thanks!
Very Nice Setup 8)
