I got one that nearly made me cry.
I was driving round with a mate and the engine had just had a tune up and new ball joints and tie rod ends.
Driving for 20 mins then go to change to 2nd around the roundabout and would u **** believe it, it wouldnt go in.
Wouldnt select any gears. I freaked out and pulled over.
Popped the hood to see if anything wasnt where it shouldnt be.
All seemed good.
Killed the engine, tried selecting gears... yep that worked.
Started engine up in neutral, tried to select gears - nup.
It would go into reverse only, but crunching it a little.
Called the RAA out,.... **** useless mob of fags they are.
They said "nah cant help u with that... we'll call a tow for u"
Got it towed back to the mini place i had the stuff done. This was saturday at 4:00pm and they close at 12.. No work could be done until monday.
I got it towed to a mates place, and he lives right round the corner.
Monday comes and he and I drive it to the place... With engine off, select gear 1 and start engine. This is the only gear that could be driven in until the engine was switched off then changed. LOL!!!
I thought the gearbox was rooted but he fixed it up on the same day... blown slave clutch cylinder. Fark that was scary.
And it only cost me 160 for it all fitted.. .new recond cyl and all.
