It is currently Sun Aug 17, 2025 3:39 am
 Post subject: What temp do you run at?
PostPosted: Wed Sep 14, 2005 9:59 pm
Hey guys, i've noticed on alot of runs that some guys seem to worry alot about the temp. Mine sits on 70 most of the time and only ever goes up if in very slow traffic.
What do your minis run at?
Ryan
PostPosted: Wed Sep 14, 2005 10:02 pm
Anywhere from 150 to 180 farrenheit
No more Minis!......For now.
PostPosted: Wed Sep 14, 2005 10:08 pm
Ha-Ha runs 1/4 up on gauge when moving, 1/2 sitting still on a hot day. Deluxe rad & MiniMatic underbonnet heater. No worries mate.. :wink:
<edit> Barney's runs at 1/2 on gauge when moving well, creeps up well past 3/4 when in traffic. He has a new MiniSpares 2 core (no heater)- I reckon they are no better than a good stock Deluxe or S one.
:idea: Must fit MiniMatic heater before Can-Bra run... 8)
Last edited by drmini in aust on Thu Sep 15, 2005 6:46 am, edited 2 times in total.
PostPosted: Wed Sep 14, 2005 10:23 pm
80c 85 on really hot days
PostPosted: Wed Sep 14, 2005 10:34 pm
160-185 and occasionally hitting 190 degrees fahrenheight.
- Simon -
PostPosted: Wed Sep 14, 2005 10:59 pm
Usually, on a clubby dash, its sits on the bootom of the 'N'. I figure this to be about 160*, as this is what my thermostat is, but when it gets to what i would call 'hot', it is realistically 3/4 on its way to 'H for Head gasket'. I presume this is about 190-200. Not danger stuff, but not what you need. :(
I've got an Auto Meter Capillary gauge to put in it, but that's just on the list of things to do. :roll:
PostPosted: Thu Sep 15, 2005 6:37 am
my mini runs very hot, to hot infact so i took out the thermostat. but even then it ran to hot, so the rad is out atm and im fixing the problem :)
PostPosted: Thu Sep 15, 2005 6:46 am
1/4 here also and slowley creaps up...but I run a normal Rad and heat, I hope it stays that way to :wink:
PostPosted: Thu Sep 15, 2005 9:40 am
Make sure you put a thermostat blanking thingy in if you take the thermostat out :shock: otherwise the water doesn't circulate the block properly, it goes from the water pump straight back out to the radiator and doesn't cool the block :shock: :shock: :?
Roads need more corners
PostPosted: Thu Sep 15, 2005 5:31 pm
yeah, I did it the not so bad way, so its all good!
I have got myself another smaller rad im going to hook up next to my oil cooler, should keep things down a little!!
later
PostPosted: Thu Sep 15, 2005 5:44 pm
the minis stays at 0 but mine changes
IT DEPENDS HOW MUCH EFFORT I AM PUTTING IN TO PUSHING THE #&#%&#((#@ THING
My mini runs at about 80c whilst driving and if I get stuck in traffic it will go up to about 100c but it seems ok.
PostPosted: Thu Sep 15, 2005 6:28 pm
was wondering...
my dashboard only reads C/H...
how do ya measure the temperature?hahah
whats the normal safe temp to run anyway?
im new,green about cars,but that doesnt stop the growing passion in me about the mini...
PostPosted: Thu Sep 15, 2005 6:48 pm
Your clubby only has C - N - H ...i'm not sure of the exact range that it is, and what the N represents as far as temperature. Anything around the 'N' is Normal..Ideally just below the N is great... but you shouldnt have too many problems as long as it's in the normal range, wait until summer :lol:
PostPosted: Thu Sep 15, 2005 7:00 pm
I've never seen mine go above about 95-100*F. I've never checked the accuracy of my guage either - I think I should...
Users browsing this forum: No registered users and 350 guests
