It is currently Sun Aug 17, 2025 5:00 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Fri Sep 16, 2005 2:06 pm
should come clean enought to get down to spares shop and buy a new set.
cleaned plugs never work as well as new ones and if they are getting that black there is something wrong.
Keep a spare set in your car if its that bad and change them when it starts to give crap.
$15 fix for a headache what a pleasure.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Fri Sep 16, 2005 3:32 pm
Um... these NGK plugs are a new set. But after 3 weeks of people starting it twice a day with choke and running for 30 secs in & out of factory, they quit. :shock: :lol:
Motor is a bit sad... I'm ripping the head off on Tuesday to recon it. :wink:
 Post subject: HAH!!
PostPosted: Mon Sep 19, 2005 11:47 pm
You two obviously have far too much folding green ( :oops: :wink: )
.....I have been cleaning plugs for years and they usually..
a. perform better
b. last longer
c. keep my wallet fuller... :D
Some plugs are just duds from the moment you open the packet...
others seem to have a heart of gold :!: (why is that :? )
I refuse to buy Champion :roll:
PostPosted: Tue Sep 20, 2005 12:09 am
Hey Doc-If you win Lotto try using the new Iridium High Performance Plugs.
Number to use is I W 20.
Designed for modified vehicle's.Cold starts/Idle stability/acceleration/engine output-
all improved
Just what you need for a Mini....
PostPosted: Tue Sep 20, 2005 12:58 am
what sort of difference do you get from these plugs?? can you notice the difference?
PostPosted: Tue Sep 20, 2005 1:17 am
They are excellent.Especially for cold starts.Plugs are pre-gapped.
When you first look at them you think the gap is huge-but this creates
space for a larger spark and improved firing performance.
PostPosted: Tue Sep 20, 2005 6:51 am
Iridium etc plugs might work better in a multivalve ricer with 20psi boost, but in a 1952 technology Mini motor I reckon it's just overkill.
This question was done to death recently on the MM site.
BTW I don't play Lotto..... :wink:
Mick, I have had dud plugs out of the packet too (NGK) - I used Champion N9YCs at the dyno day to blow most of the 1275s away... :lol:
Users browsing this forum: No registered users and 273 guests
