It is currently Wed Aug 20, 2025 9:55 am
 Post subject: What Cam is this???
PostPosted: Tue Sep 20, 2005 3:10 pm
What cam is this?
And how much is it possibly worth?
i have no need for this cam
its pretty good nick, with no grindings or nothing on it.
and it has no markings or names/numbers etc
Image Image
 Post subject: re cam
PostPosted: Tue Sep 20, 2005 3:33 pm
looks like a standard 998/1100 cam probably worth a whole $5
PostPosted: Tue Sep 20, 2005 4:09 pm
YESSSSssssss........i might just use it as a weapon
Image Image
PostPosted: Tue Sep 20, 2005 4:44 pm
Am I seeing 2 cast rings up near the "Big" end ?
(Opposite end to oil pump drive)
Could be something special..... Doc ?
J
PostPosted: Tue Sep 20, 2005 5:27 pm
After using max brightness and having a good squiz, I'm with miniimports- it's just a narrow lobe stocko, fuel pump drive & all. :lol:
Either belt someone over the head with it, or regrind it to something useful. :wink:
PostPosted: Tue Sep 20, 2005 5:45 pm
ah mannnnnnn comon DOC cant u do better than that? what does it take to grind it to something farkin kool, that would make a mini go faster? and costs......
Image Image
PostPosted: Tue Sep 20, 2005 6:02 pm
Send it up to Graham Russell :wink:
I wont quote a price...but give him a call 9630 2195 :wink:
PostPosted: Tue Sep 20, 2005 7:30 pm
Probably around $120-130, + return post- for an RE-13 grind. Cheap performance. Don't forget to buy a new set of cam followers to go with it... :wink:
PostPosted: Wed Sep 21, 2005 7:23 am
go to a local supplier and get a prize then next time a mini run is on take the cam down there and have a cam toss competition, for $2 you get 3 attempts to throw it as far as you can, give the winner the nice prize you were sponsered and go spend the $$$$'s that you made on throwing a cam around on a new billet or 2nd hand cam and have it ground to something decent that you can use in your mini.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Wed Sep 21, 2005 9:38 am
not a bad idea actaully.............. :)
Image Image
