It is currently Mon Aug 18, 2025 1:33 pm
PostPosted: Wed Sep 21, 2005 6:36 pm
This is possibly very silly, but seeing as I know nothing about cars, I'm going to ask...
When I put the choke in my car keeps revving really high, until I push on my accelerator hard (so it revs higher than it has been), then it settles back down to a more normal idle.
What's the go with this? Is it something possibly fixed easily, or should I just rush it to a professional?
Thanks in advance!
PostPosted: Wed Sep 21, 2005 6:47 pm
your choke assembly is probablygetting caught on the idle increase screw. Try cleaning the carb with a can of carb cleaner and then a touch of WD40 To keep in lubed.
No silly questions, we all started somewhere.
Aaron
PostPosted: Wed Sep 21, 2005 6:48 pm
it's a silly question seeing as i have to even look up what you are talking about.. the joys of having no mechanical background!
thanks though! :)
PostPosted: Wed Sep 21, 2005 6:52 pm
the carb is the round pot thing that sits at the back of the engine bay closest to the window. in the middle.
Aaron
PostPosted: Wed Sep 21, 2005 6:54 pm
:) thanks, i thought so, but *sigh* i'll eventually get it, i'm sure.
PostPosted: Wed Sep 21, 2005 7:00 pm
get a manual and join a club or group. i think there is a group in wollongong. Get a hold of them and i am sure they will be happy to point you in the right direction.
Aaron
PostPosted: Wed Sep 21, 2005 7:30 pm
knk.. :wink: No its not a silly question...but its smart that you asked a question so you can learn 8)
I wont ask what size carb...but if you can put a pic up and we'll lead you in right direction...yer your choke is sticking...not a hard thing to fix.
We all start some were, Both Aaron and I have Pulled many engines out now and also rebuilt them. Your are always learning..I have bugger all idea's about the gear box's :wink:
PostPosted: Wed Sep 21, 2005 7:49 pm
I had similar problems with my choke i found it was the cable i pulled it out and put some oil down the tube slid the cable back in the tube and that fixed my problem.
If you ask enought questions you can learn anything and there is enough
people on here to help out with any problems you will come across with your mini. Hope you find the answer to your problem.
ADAM
I swerve and hit people at random.
Users browsing this forum: No registered users and 321 guests
