It is currently Fri Jul 18, 2025 11:09 am
 Post subject: 89 civic
PostPosted: Tue Sep 20, 2005 10:17 pm
would the engine out of an 89 civic hatch go into a mini?? my nan just blew it up so im thinking maybe if i can get hold of the car i could do a rebuid or sumthing, car is excellent apart from that, im using its brakes for sure!
Potato
PostPosted: Tue Sep 20, 2005 10:26 pm
yep, D15 motor, that's what I'm putting in my van, it's likely to be a twin carb motor, 92hp standard. Single cam 16 valve, you can buy a second hand engine for about $500... Though I wouldn't bother with it, you're much better off with a suzuki, unless you have a special reason to go with it like me
here's a pic of the motor sitting in (part of) a mini subframe and in the engine bay
I'm amazed she managed to blow it up - I thought that was impossible with Honda motors. The guy I work for has an accord from about that vintage with 320,000 K's on it, still runs great... it idles a bit funny, but otherwise :lol:
PostPosted: Wed Sep 21, 2005 6:01 pm
hmm well the car has barley any power and the catalystic converter is glowing red when u run it, so i dunno, but if it is just the cat i will whack it in the white one :twisted:
Potato
 Post subject: reason??
PostPosted: Wed Sep 21, 2005 11:20 pm
and what might that be?
PostPosted: Thu Sep 22, 2005 8:16 am
I was wondering that too....... :roll:
Bob Slattery
PostPosted: Thu Sep 22, 2005 8:28 am
So are you going to weld up the subframe for it meeni?
Aaron
PostPosted: Thu Sep 22, 2005 12:03 pm
you guys just aren't observant enough, follow the link in my sig...
PostPosted: Thu Sep 22, 2005 12:57 pm
I was gunna say isn't that a 4WD engine?
Sounds like a 1-off mini alright.
PostPosted: Thu Sep 22, 2005 6:57 pm
Aaron
is that sarcasm or are you seriouse? im thinkign about it, probably wont though cos the engine has a problem, if anyone wants the motor though... im breaking the whole thing, all the parts from the civic are going
Potato
PostPosted: Thu Sep 22, 2005 7:18 pm
if the seats are any good, they go quite nicely in a mini, and I find them pretty comfy, the car I wrecked had seat covers on since new
PostPosted: Thu Sep 22, 2005 7:50 pm
I don't know but has the engine been run on a leaded fuel sounds like the cat has clogged causing the low power and cat to glow.
4efte powered Clubman
supercharged 998 race car
PostPosted: Thu Sep 22, 2005 8:37 pm
is there any way i could fix the cat blockage without buying a new cat??
Potato
PostPosted: Thu Sep 22, 2005 8:47 pm
Disconnect the exhaust before the cat and see if it runs properly
PostPosted: Thu Sep 22, 2005 8:57 pm
If it the cat, take your old one along to a wreckers & get a used one.
Give them the old one, as they scrap them for the platinum, or they will charge you more.
PostPosted: Thu Sep 22, 2005 9:00 pm
yer but im not planning on spending an awful lot of money on it, just if i can fix it nice and easy i will, cos its a real nice little car, would be a shame to kill it
Potato
